Old 09-13-2012, 05:03 PM
Sony KV 5000 Trinitron
Anyone know what these controls stand for and do?
They are at the back of a Sony KV 5000 Trinitron.
R BKG B BKG G BKG
Looks like one can insert a screwdriver to adjust, just curious as to what they do.
Old 09-13-2012, 05:29 PM
crtfool's Avatar
crtfool crtfool is offline
Red Background
Blue Background
Green Background
They control the intensity of the 3 guns, as well as the RGB Drive controls - which are adjusted internally.
Old 09-13-2012, 06:25 PM
They are good for keeping a B&W image from being tinted, and the colors more true on a color show.
Old 09-13-2012, 07:21 PM
I suspect that the more fragile low power directly heated cathode structure employed in the CRT for this set may have been more prone to minor spacing changes... nice to have these three controls, as well as the "screen" adjustment readily available for minor "touch-up".
Old 09-14-2012, 08:01 PM
Thanks. My set has to "warm" of a color image. Would like to adjust without opening the set. Know very little about internals. Do you think if I adjust the B BKG, I could "cool" the image? Or a combination of the three?
Is the Screen adjustment used to adjust the size or position?
Old 09-14-2012, 10:04 PM
I don't have the calibration procedure, but I would try either turning the red down a bit or the blue and green both up a bit to see if you can obtain a more balanced picture. The "screen" control affects the overall brightness of all three guns.
Old 09-15-2012, 12:22 AM
I'd, with a B&W picture, turn the blue down to min then balance the remaining two controls for true yellow then crank the blue back up until a true white is obtained. I use this procedure on tube type equip so YMMV.
If the B&W image is already tinted badly then what do you have to loose?
Old 09-17-2012, 04:58 PM
I set up a mirror in front of the screen and watched the effect as I turned counter clockwise the R BKG slightly and then the B BKG clockwise. On a Black and white movie, looks better now, more grey less sepia.
Have ME TV, RTV and THIS over the air channels for old movies and shows like Bonanza, Mary Tyler Moore, Bob Newhart ...
Old 09-18-2012, 10:56 AM
Magnavox used to boast about their sepia switch.
They said it adds a pleasing sepia tone to old movies.
Old 10-18-2017, 09:12 PM
Popester's Avatar
Popester Popester is offline
Etype2, I have the manual and could take pictures of grey scale adjustments PM me if you want pics. Popester.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 10-18-2017, 09:15 PM
Popester's Avatar
Etype2, sorry I misread the title. I thought it was a KV4000. That is the manual that I have. Not the one for KV5000. I would think grey scale adjustment would be similar.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 10-20-2017, 12:29 AM
Popester,
If you have the KV 4000 manual, would appreciate a copy. I have a KV 4000.
