Old 09-17-2012, 01:43 PM
well I only have enough of the correct caps to do 2 cans, so I will be going over it and making up a list of caps for the whole set for order, then I can sit around and stare at it while recouping on the hand....
I should prob order enough to do all 3 of the CTC-5 chassis just to cut down on the shipping cost. would be nice to have 3 working chassis.
Old 09-17-2012, 07:09 PM
in my desperation to do something went ahead and cut the cans off and drilled the bottoms with my pin drill. Installed the caps in two of the cans.
Old 09-17-2012, 10:07 PM
while putzing with it I noticed what looked like a mod in the contrast circuit, a 68ohm resistor/cap tacked in between point "T" of the video board to the contrast, also the contrast pot has a 50uf cap and 1k resistor (like a cathode bypass setup). It would seem this is some kind of mod to the video amp tube cathode bypass.
