Old 09-18-2012, 12:22 AM
lnx64's Avatar
lnx64 lnx64 is offline
Velocity Modulation Scanning
I have a SHARP TV from my Mom, it's a 27", and it's currently in the garage.. I currently don't use it because, while it has Component inputs and is 240p/480i, it's contrast is not very good.. Not a bright tube, and was like that even brand new.
But it has a feature called Velocity Modulation Scanning, something makes the picture look rather...........weird.. It's like a sharpness filter, without ringing, but it seems to make things look un-naturally sharp.
I don't know, my Sega Genesis, which is 320x224, looks FAR too sharp to be 320 pixels wide. (The Genesis is Component video modified so it isn't getting any NTSC output).
http://img.photobucket.com/albums/v3...gon/genset.jpg
(This pic was taken nearly a year ago).
Old 09-18-2012, 10:26 AM
Old 09-18-2012, 07:20 PM
Sharp tv's are the best ! ! ! <hillbillyhtml>dancing banana</endhillbillyhtml>
I see you have a 7600 sitting on the desk... you still use it?
Old 09-18-2012, 08:46 PM
lnx64's Avatar
It's a 7500 actually. It's dead sadly. I replaced everything in it and still can't get a picture. It's like the case is haunted.
Old 09-18-2012, 09:26 PM
Brandon, aren't you in San Diego?
Take a look at this:
http://sandiego.craigslist.org/esd/ele/3273829263.html
You should stop fiddling with low end stuff and get something like that, it's probably less than you paid for a new Flyback for the Samsung.
I'm not trying to knock you or put you down for tinkering with the Samsung if that's what you enjoy doing, but if you want a CRT set with a really good picture that's not HD you should check out the XBR, if not this one then maybe an older model.
It's probably a lot more tweak-able too, my XBR had zillions of adjustments in the Service menu, far more than I was comfortable playing with.
Old 09-18-2012, 11:05 PM
lnx64's Avatar
I'm in Orlando FL.
I'm just ok with RF only TV's. It really doesn't bother me, and I really do love this old Samsung of mine.. I finally have it buttoned up for good and am now enjoying it.
