I found a picture of someone elses set showing the back, you can also see the HV cage, it may be metal, you can't really tell from the picture.
Hi Eric..
Pulled it out of the garbage and sure enough, its a 10 inch and not a 12inch crt. Thanks for making me double check!! Dont always believe what you read. I have a weak 10BP4 which will suffice for testing etc once I get a chance to start work on it. Thanks for the pics of the little knobs, that helps a lot. |
