1950's photo of a pretty rare set
Surfing through Ebay, I found this 1950's photo showing an operational Westinghouse H22T155:
http://www.ebay.com/itm/Three-Women-...item23233bff56 It is this model: http://www.earlytelevision.org/westi...e_h22t155.html |
Ooops, the Ebay link is not working. Type "Three Women Watching TV In The 1950's" on the search space on the Ebay site and you will find the photo.
You have to right-click, then open a new tab (or window). It may be a Westinghouse color set...but it very likely is not. I had a blond console with identical control layout that was a painfully ordinary black & white set. It did have series filaments and a ZAPPING! hot chassis just like its color clone, but otherwise the similarities were confined to the outside.
tvontheporch.com |
Messing around with the photo bumping up the light level reveals no evidence of a color convergence panel on the left side.
tvontheporch.com |
Back to the original set in question, does anyone have one of those 1957 Westinghouse color sets? Also, can you just imagine trying to find a CRT for it?
Still a neat picture...
Benevolent Despot |
http://videokarma.org/showthread.php...t=westinghouse |
Too bad the Ebay pic wasn't in color Also too bad the anonymous collector couldn't have rotated the deflection yoke to provide an upright picture. Or perhaps it was screenshot of a past NASA space mission?
I seem to recall the same cabinet used for a black and white set I once came across. Nevertheless, the convergence panel depicted in the ETF photo appears to be on the other side of the Ebay photo TV cabinet. I cannot see any difference between the ETF set and the Ebay photograph. |
Surely not a color set - Westinghouse would not have allowed a photo of a misadjusted picture on the color set, plus the subject of the photo clearly is instructional TV and not color per se.
Try this link it works. Good that you guys are able to preserve that history .
http://www.earlytelevision.org/Deksnis/home_page.html Last edited by tubetwister; 10-09-2012 at 09:02 PM. |
Very true. I was only mentioning that the cabinets only looked identical. Perhaps Westinghouse, for its experiment, simply used a standard production cabinet and stuffed it with their color prototype chassis?
Where does it say this photo has anything to do with Westinghouse?
Looks like a Closed Circuit Classroom to me, note the Chalkboard and the Teacher looking Woman standing next to it. ![]() Maybe they were watching the Letterboxed version. |
I agree the taking of the photo had no relation to Westinghouse and I can't think of a reason there had to have been one if the set actually was one of their color TVs.
tvontheporch.com |
I tried the usual enhancements on the photo and could not see the convergence panel. The speaker is indeed in the correct location, however. On the color set, the convergence panel sits quite flush with the side of the set, and the color and hue knobs are recessed, so it/they might not show up very well (or at all) in the eBay photo, which is shot only slightly off axis.
For grins, I ordered a copy of the photo for a closer look. Add: Attached is a photo from approx the same angle... the front flash helps, compared to the eBay photo in a dark corner. jr Last edited by jr_tech; 10-10-2012 at 12:45 AM. Reason: Add pix |
I was just about to attach a copy of the pic to the thread for posterity, but now I'll leave that to you.
