well that worked well enough, I had some stiff plastic tubing that makes a nice guide for the precision screw driver. I just need to make up two more (have to find a couple more precision drivers) and will leave them in place. the static looks good but the edges are way out of whack the V G/R is way off on both the right and left side, but seem more so on the right (facing screen). Anyway will proceed with the convergence before swapping the CRT into the good cabinet. I am wondering if I should attempt to swap the entire bezel with the CRT attached, as opposed to pulling all the stuff off and having to re do all the setup (assuming I can get it good on the current set).
