Sounds like you may have it fixed. Just monitor the temperature of the HOT heatsink after it's been on a few minutes. If it's too hot to touch, you likely have problem and the HOT will soon fail again. If it's comfortable, let it run and check it again in 30 minutes, then after an hour, and so on. It will get hotter the longer it stays on; but, if it gets too hot to touch, you may have other problems. And, it doesn't matter which direction the degaussing plug is inserted.
http://www.youtube.com/user/radiotvphononut |
