Old 12-08-2012, 05:33 PM
Dangler's Avatar
Dangler Dangler is offline
Talking Some pics and a little more info found
The top as well as the sliding door are glass with a fake wood finish on the reverse side.
The changer is a "Magnavox Deluxe", 3 speeds. Made in England. A little research turned up "Collaro Conquest" as being the same thing.
The TV portion has 17 tubes and a 24AHP4 picture tube.
The TV tuner is located in the AM/FM radio portion of the cabinet.
The amp uses four 6V6's, two 5Y3's and a 12AX7 for the pre-amp.
The radio is AM/FM with a green tuning eye.
All of the controls for the TV are located above the radio.
It probably wouldn't hurt to replace those crossover caps on the speakers
I only paid $20.00 for it. Might make good "Fish Tank"!
I'll search Sams and see what I can find on the changer.
Just kiddin' about the fish tank.
" I'm gonna fix that one of these days"
Old 12-09-2012, 10:00 AM
marty59's Avatar
marty59 marty59 is offline
Okay...we've got somethng to work with here!
The Collaro changer is a model RC-456 and is covered in H.S. 342-3. it has lots of good mechanical and set up info but nothing electrical.
The Amplifier should have an ID on it that is simply "AMPxxx". Looks like a nice amp!
The Tuner/Pre will be labeled something like "XX-XX-XX".
Ah, the TV chassis...simple. It a V26-03AA, aka a "26 Series". It's covered in H.S. 404-3.
On your changer, is just the plug missing? Still have the wires, (red, yellow, black) correct? I can help you ID the wiring and I may have an extra three prong plug for you and can post a pic.
Old 12-09-2012, 11:42 AM
Dangler's Avatar
Thank you very much, Marty!
I did some wire tracing last night and now am not sure if the socket on the amp was used to power the phono. That's what had me wondering since the changer is not getting power.
The amp is a Amp142-OC
The yellow wire from the changer goes to a switch inside the changer compartment marked Auto/Manual and shut off. From the switch, the green and black wires go to a plug that plugs into the back of the radio chassis. The other two red and black wires from the changer go to the same plug on the back of the radio. There is a place on the far right of the amp that says "Phono Motor". Now I'm thinking that might have been a provision for the amp being used in a different style cabinet with no TV.
I'm going to check the switch to make sure it's OK and check the socket on the back of the radio to be sure it's getting voltage.
Thank's again for all of the info. I'll let you know what I find out.
Old 12-09-2012, 02:17 PM
marty59's Avatar
The power should be switched by the selector on the tuner/pre I believe. I have not been around these all in one type combo's with the TV but (and you may have to determine) if this unit is set up to power either the TV or the radio/phono/amp seperately or not.
Magnavoxes of this vintage (in general) were designed that if you were playing a record for instance and after the last play the unit would cycle and power everything off. I'm not sure how the TV function plays into all of this. That amp would be really cool if it's switched for the TV audio!
Unfortunalely, schematics that contain seperate pieces don't always cover the "interfacing" of everything together as a whole but you may need to gather as much info as you can and troubleshoot from there.
Old 12-09-2012, 04:38 PM
Dangler's Avatar
I got the changer working, broken wire somewhere inside of the insulation. Just replaced it. Now I am going to have to get a new cartridge. The original is an old Astatic 463 ceramic type. I have a Shure 742 that will bolt right in, but I don't know if it would be any good after all these years. I might try it a little later. The Shure is kind of a weird design in that instead of the needle flipping over for 78's or 45's, it has two needles that are side by side and move into a metal groove when the lever is switched like a conventional cartridge. It looks like both needles would be in contact with the record at the same time.
The TV audio does in fact go through the amp, so it should have pretty good sound.
I'm going to order some electrolytics for the TV, amp and radio tomorrow and take it from there once I get those replaced.
The amp doesn't hum...yet, but I'll replace the caps as a precaution. I've been listening to the radio and am pretty happy with it.
Old 12-09-2012, 06:07 PM
marty59's Avatar
Sams does list an AMP142AB, should be the same 311-9.
Old 12-09-2012, 06:56 PM
The folks over in the AudioKarma tube audio forum think highly of those Magnavox amps.
Old 12-09-2012, 07:27 PM
Dangler's Avatar
That will be handy if I decide to replace the ceramic cartridge with a magnetic one, but I don't really know if that's what I want to do. I noticed there are some magnetic cartridges that can be installed in the metal mounting bracket.
Is there any way to test the old ceramic cartridges besides hooking them up and running a finger across the needle?
I'll swing on over to the "Other Side" and see what they have to say.
Sure would be nice to listen to some old 78's on it.
Thank's again for all the help, Marty. I really appreciate it.
