yes, and the power factor as well. For the most part the test well over like 50%, if it was under I would reject it outright. I like to compare them to new caps, they generally test higher value, about the same in power factor, and up to about 2 to 4 times the leakage (but its still very low). I used to have a chart that was used for acceptable leakage.
It would not be uncommon for me to take more that 24hrs for one section. Is this really needed, maybe not but it cant hurt to try and besides like I said before it appeals to my interest in experimenting. What I would really like would be a test setup that I could program to step up the voltage based on current, say have it ramp up to try and maintain a set constant leakage current (selectable), then graph that voltage over time and set the max voltage to end the test. The resulting curves would be fun to examine. you could do it with a constantly variable DC power supply and a current meter (analog would be easy to watch) but I dont really want to stand by the PS and work that for however long it may take. Last edited by DaveWM; 12-31-2012 at 08:31 PM. |
all the sections seem to have responded well to reforming. I will set it aside and check it in a couple of weeks.
interesting graphs, would like to see both graph at 200 seconds. for 1 and 4
Also if you reran the test on the old caps does the graph change (reformed) so the low current target at rated voltage is reach sooner. I looks like the 82uf took that long to hit max voltage, perhaps for reforming you could ramp down the current to say 1ma max. Very neat project. |
Here is a plot of 1 up to 250 seconds. Is that what you mean?
Hi All;
I would like to see a circuit diagram ?? So, I can build one as well .. THANK YOU Marty |
[QUOTE=DaveWM;3058394]Also if you reran the test on the old caps does the graph change (reformed) so the low current target at rated voltage is reach sooner.
QUOTE] I ran the reform process again on the two old RCA caps and attached are the plots. Yes, they got a better result from a second reforming. They both still show a lot of dielectric absorption, as seen by the LC75. Last edited by Zenith6S321; 02-16-2015 at 06:31 PM. |
[QUOTE=Zenith6S321;3058457]
I have reformed quite a few capacitors with a simple variable DC supply. (I first used an old variac, rectifiers and series resitance but now use my Sprague T06 capacitor checker). I assume by diectric absorption you are referring to leakage? Certainly the older capacitors leak more than newer capacitors. But that was normal. What is important is the leakage is kept under control and that it remains low. I find gently reforming and lengthened testing results in a higher percentage of saved capacitors. The leakage current scale on the graph is too high which does not allow you to see the resultant leakage current accurately. You must be able to ascertain that the leakage is below 0.2mA inn order to determine whether the capacitor is good or bad. The resistance indication on the graph is interesting. Perhaps the fluctuation is the dielectric rebuilding process? |
Until I bought and started using the LC75 I had not heard of dielectric absorption. Here is a good description that echoes what is said in the Sencore manual: http://en.wikipedia.org/wiki/Dielectric_absorption It goes on to say that all capacitors have some amount of this and its generally not a problem for capacitors used in power supply circuits. Quote:
The pulse width has a range of 0 to 255 with a value of 127 producing a 50% duty cycle waveform that I use as the upper driving limit. When the leakage current gets low a single increment in the transformer drive can make a sizeable change in the quadrupled output voltage. Last edited by Zenith6S321; 01-08-2013 at 06:47 PM. Reason: Clarification |
