Old 01-14-2013, 10:13 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
At least replace the ones that will pull B+ to ground through those unobtanium parts when they short.
Old 01-15-2013, 12:47 AM
I agree with VK members Zenithfan1 and Einar72 -- recap the set before going any further. As a minimum, I'd replace the power supply filter capacitors. Your TV was made 63 years ago, and these capacitors are almost certainly defective. At best, they will allow 60-Hz AC hum into the TV's deflection, sync and other circuits; at worst, if these capacitors short, they can burn out the power transformer (by putting a direct short across the output of said transformer) if they don't blow the TV's own line fuse or the house fuse/breaker first.
Good luck, and I hope you get this set working. It may take a while, but when you get it working well, you will have a TV to be proud of. You won't see HD pictures on it (this set was built for the old NTSC television standards, so at best you will see a picture with black bars at either side and/or at the top and bottom, which can be compensated for using the zoom button on your converter's remote), but the picture you will see will be, owing to today's DTV standards, much sharper and clearer than any NTSC picture ever was. I grew up watching NTSC TV; when I got my flat screen about a year and a half ago I was amazed at the difference in picture quality between my RCA CTC185 19" portable color set (which, until then, I had been using for over ten years on cable) and the new flat set. You have probably already noticed this since you have a converter box on your GE portable, and have been watching Indianapolis TV in digital format since Christmas. Your Arvin console has a larger screen, though, so you will have that much more picture to see, even with the letterbox/pillarbox effect common when viewing HDTV on a standard TV.
Old 01-19-2013, 07:12 PM
radiotron's Avatar
radiotron radiotron is offline
johnny the raster master!
ok
im done recapping, and it still didnt come on so i replaced every hv tube
damper tube 5u4 1b3 6cd6 and it still doesnt come on no hv!
does anyone know what it is 6sn7?
Looking for zenith cobramatic parts
-johnny the raster master!
Old 01-19-2013, 07:28 PM
Geist Geist is offline
Hi All;
Radiotron, I am suprised with a name like "Radiotron" that You do not know what a 6SN7 is.. It is a twin Triode, mainly used in Oscilators and in sync limiter or amplifier circuits.. In alot of sets, a number of the miniture tubes could take its place, such as the 6/12 AT7, 6/12 AU7 etc.. And many others..
THANK YOU Marty
Old 01-19-2013, 11:46 PM
I'd check the resistors around the 6SN7, maybe one went open.
Old 01-20-2013, 08:05 AM
radiotron's Avatar
Originally Posted by Geist View Post
Hi All;
THANK YOU Marty
yes i know what a 6sn7 is, and this set has 2
its just the face thats the only ones i have
Old 01-20-2013, 11:02 AM
Hi All;
Sorry, Radiotron, I misunderstood your origional question..
And, I have no clue about your answer, either..
THANK YOU Marty
Old 01-20-2013, 05:29 PM
Oh, let's not bust the kid's chops too much, think of the errors we all made when we were learning this hobby. The ones that make us cringe today...
When I have a TV or radio that works on its original caps, I won't run it that way very long. I take it as an assurance that the time money and effort I'll spend recapping it will likely be successful.
