Old 01-23-2013, 05:02 PM
josephdaniel's Avatar
josephdaniel josephdaniel is offline
Learning as I go
Never mind
Last edited by josephdaniel; 01-23-2013 at 05:03 PM. Reason: Knew answer to question
Old 01-23-2013, 06:38 PM
Doubt it's just the 6SL7 tube causing your troubles. Waves could be some hum in the power supply. Do you have something like a B&K 1077 to inject signals into the video IF stages ?
Old 01-23-2013, 07:01 PM
Learning as I go
No I don't have any signal generator.
Is it ok if I used electrolytics in place of the film caps in the ballest?
Old 01-23-2013, 08:10 PM
Are they non-polarized ? Ideally I think motor run caps should be used because they're designed to handle continuous AC current.
Old 01-23-2013, 08:17 PM
Learning as I go
I havent replaced the filters yet (probably should have done that first... DUH
about the ballest I had the set on for a few minutes (longer than I have ever had it on) and I noticed the electrolytics were getting very hot and begenning to vent. Motor run caps would probably work good but arnt they in big sardine cans filled with toxic preservatives like PCB I know the old ones were not shure about the newer ones.
Old 01-23-2013, 08:30 PM
Yikes! Yes, you need to use non-polarized caps. They stopped using PCBs in caps a few decades ago so no worries there unless you dig up some ancient ones.
I used a plastic film motor run cap like this in my Predicta Holiday. I've used regular film caps too, but I'm not sure how well they'll hold up under extended use.
http://www.digikey.com/product-detai...9401-ND/207387
Old 01-23-2013, 09:42 PM
Learning as I go
I will probably buy those soon since I plan to watch this tv nightly after i get it working!
Old 01-23-2013, 09:53 PM
Be sure to check the dimensions before you do. They're too big to fit inside an original mesh metal ballast tube.
Old 01-23-2013, 09:57 PM
Learning as I go
I could probably stick em under the chassis if they don't fit.
Is there a way I could inject a signal in the if stages without a signal generator?
Old 02-14-2013, 07:53 PM
Learning as I go
bump...
I haven't been able to work on the set lately had a ton of school work but I did get the ballast fixed but it still does the same thing. anyone any ideas? even remote possibilities?
Old 02-14-2013, 09:53 PM
Did you replace the filter and all the paper caps ? Are the ballast caps still getting hot ?
Old 02-15-2013, 07:06 PM
Learning as I go
no I replaced the capacitors in the ballast with film ones so it does not get hot anymore I got all the paper caps replaced except for one .004 at 600 volt cap and I have not replaced any of the filters yet bu I will probably get to that on Monday since I don't have school.
Old 02-18-2013, 05:53 PM
polyphase polyphase is offline
Originally Posted by josephdaniel View Post
The lines move side to side but those vertical lines are not there in person
That pattern looks like audio to me. Those tightly packed vertical lines would be the 4.5mHz FM audio subcarrier. Do the lines go away with no input signal? If so, I would be pretty sure of it.
