Hi All;
Sorry to hear about the filament.. Maybe you should have gotten the old Dentist tools and been on your way to rebuilding your own filament, with it.. Since you are so good at everything else you do, tv's, speakers, radio's etc.. THANK YOU marty |
Very '60's looking set Bob! That'll be loads of fun to watch vintage classic shows on when it's up and working.
Thanks, I think so too. Oh, I almost forgot to mention that I powered it up and I have sound and HV
I read somewhere about rubbing walnuts on a water stain...
GE, the power supply is un-stoppable just like a Westinghouse...both true to thier electrical distribution equipment roots. |
I was pleased to see a proper power transformer and 5U4 rectifier rather than a hot chassis selenium voltage doubler
The VFW hall we rent out for our model railroad club has one of these fans, with a 20 foot power cord. It's really powerful.
Those are sure interesting and different sets. I think they also had one model that you could actually remove the portable TV from the console if you wanted to take it to another room.
If you connect your meter to the filament pins and set it on the audible continuity range and tap the neck and you hear short beeps you may be able to weld the filament back together. I have done it with success using a 40vdc supply that is current limited to 1 amp. Tap the neck and when the filament welds, the current sense circuit kicks in and reduces the voltage and limits the current. I have done it twice and the fix has held. Not sure if it matters but I also wired in a 47mfd electrolytic in parallel to the supply to add a little extra kick. You've got nothing to loose.
Tim |
Thats one neat looking set Bob, the styling is very much like some of our NZ native built TV's
Looking at the top dual concentric knob thats not missing, I recognized it straight away as it looks to be identical to the knobs used on some Philips b/w sets made in NZ. Heres the link to a Philips TV on my site showing the same controls - http://nzvintagetvradio.blogspot.co....z23cz327a.html I can take a better up close shot of these controls if it helps. Hope you can find a CRT for the GE, its worth saving I reckon ![]() Cheers Glen
Visit my Vintage TV & Radio Page - http://nzvintagetvradio.blogspot.com/ My YouTube Link - http://www.youtube.com/user/glenz1975?feature=mhsn |
If the heater's open I wonder if it's also gone to air?
Perhaps. I'll pull out the set once I get some service info and take a closer look. I figure I can use a little 8YP4 while pondering the CRT situation.
I just finished scanning the docs. Here's the original receipt from January, 1959 for $386.25. The hardware store where it was purchases is just a few block from where I picked up the set. ![]() It's made from genuine walnut. ![]() Here's a page from the owners manual showing the knobs,. ![]() UHF operation
Does anyone have data for a 21ESP4 CRT ? All I know about it is the pinout from the radiomuseum. The dimensions look right for the GE and the filament specs match, but I'm not sure about the HV and grid voltages. Thanks.
http://www.radiomuseum.org/tubes/tube_21esp4.html |
The ES, looks like it's good for a little more high voltage. I would try it.
