#46
From the article it appears they are using 12 gauge wire with 18 gauge solid insulated wire interwound. It wouldn't matter that the 12 gauge is bare wire, stripped from a scrap of house wiring, since the 18 gauge hookup wire has its plastic insulation.
#47
The easiest converter, WORKS good!!
The easiest converter works awesome on my philco prewar set. It helps if the set is sensitive w/ good volume since circuit is passive. MY westinhouse postwar early FM has a similair type circuit for it's FM part.Showing two specially wound air coils, along w/ 2 pairs of copper plates for tuning cap especially for FM use.
I've seen rare prewar to postwar converter selling for big bucks. I would rather make this --- and save sevral hundred dollars.
1977 Zenith Chromacolor II A Very Modern Zenith |
