Old 04-17-2013, 08:42 PM
...You could just unsolder the CRT socket filament wires of the set at the point where they are soldered to the chassis and insert the isolation brightener filament transformer there...That way you would get all the isolation and none of the capacitance video smear.
That wouldn't help a bit, because the offending capacitance occurs between the secondary and primary windings of the transformer itself (the primary being grounded).
As a side note, on some solid state sets that have the CRT heaters running off the flyback ("scan-derived" supply), you can isolate an H-K short without getting the smearing. That's because the capacitance-to-ground is negligible when you 'float' the heaters and their supply winding.
