Old 05-01-2013, 09:40 AM
It might be a good idea to check those 2-watt carbon comp resistors in the chroma/demod area. If the set has a lot of hours on it, some of those are almost guaranteed to be low in value from charring on the inside.
Old 05-02-2013, 07:08 PM
There are no 2 watt resistors by the 'X' and 'Z' color demod transistors unless those rectangular resistor coded pieces of brown ceramic that I always thought were chokes are actually resistors.
Old 05-03-2013, 10:56 AM
There are no 2 watt resistors by the 'X' and 'Z' color demod transistors...
Yes that's apparent in the photos that were posted subsequently. It is a different chassis than what I was referring to, possibly with factory mods to eliminate the charring resistor problem.
