Old 05-01-2013, 03:12 PM
Originally Posted by Robb View Post
Now I need to find a power cord for it. I dont even know if it works ! hahaha
If you can find out which two of the four pins of the AC/DC power socket are used for AC input (this info should be on the schematic diagram), you could use a standard TV cheater cord. I use a 4-pin cord meant for a Sony AM-FM radio to power my Zenith K-731 and also one other radio in my collection. Works very well. Also, I use a cord designed for a Panasonic boom box to operate my Zenith R-70 AM-FM portable on AC. The female connector fits the male AC power socket on the back of the radio perfectly. I also found that cords meant for use with Norelco electric razors also fit the AC power socket of the Zenith R-70 and R-7000 just fine.
BTW: is your TV one of those AC-DC sets that can be powered from batteries or AC house current? If so, I would think it is quite rare, as I have never seen an AC-DC color set before this one. The reason is power draw. Even solid-state color TVs draw much more current than monochrome sets; as such, the former could, and likely would, drain a set of batteries in no time flat -- unless this TV is of a very special design that doesn't draw much current.
Old 05-01-2013, 03:14 PM
Robb's Avatar
Robb Robb is offline
It's house current or Car/Boat plug-in I assume.
No batteries.
What I dont understand is if I used a 4 pin cord like the Sony, how does it know which voltage to use ? (12v or 120v)
flickr
Old 05-02-2013, 01:33 PM
Phototone Phototone is offline
No batteries.
OK, while there are 4 holes on the end of your cord, there are only 2 that carry the 120v. Notice the plug has a orientation tab, you can only plug it in ONE WAY. That is to make sure the 120v goes to the correct pins. The 12v cord would have the 12v to the other 2 pins.
