Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > Early Television Foundation CRT Rebuilding Project
Old 05-26-2013, 09:10 AM
WISCOJIM WISCOJIM is online now
Originally Posted by jhalphen View Post
In RACS's 35 years of operation, even when the plant had 30 employees, François R. was the only person who took apart & reassembled guns.
Question:
Would Hawkeye's Scotty accept to do this? his residing on US soil would really make things easier/cheaper.
Hi Jerome.
Do we know if Scotty even did this himself, or did he order his guns from elsewhere?
Old 05-26-2013, 09:19 AM
One of the things I was thinking.... And one reason I believe b&w tubes will be the first to be done, and color a few years behind that....
jhalphen: Would you be able to write back with detailed description and if possible pictures of the procedure used by them for the exact process used to deconstruct, and rebuild a gun? What methods are used to measure spacing on an old gun before its taken apart? Do they deconstruct the entire gun, or just the end near the heater & cathode?
Do they re-manufacture the grid emements, or re-use those components reclaimed from the old gun?
And how is that glass bar made that holds all those elements together? Is it melted and the tabs pushed into the glass bar, or some other method?
Thanks....
Old 05-26-2013, 10:14 AM
jhalphen's Avatar
jhalphen jhalphen is offline
Hi SquirrelBoy,
I will endeavour to answer your many questions.
See 10 photos on my PhotoBucket site of the gun rebuilding process taken by RACS, showing a gun at various steps of reconstruction:
http://s281.photobucket.com/user/jha...?sort=4&page=1
If interested to see the rest, the root directory of the entire CRT rebuild process is here:
Obviously much more data is required. I will ask, but it will take time.
When at RACS, i saw an assortment of measuring tools, calipers, gauges, palmers,... sorry, i don't have too much vocabulary in describing tools for mechanical measuring.
What is taken apart: depends on the gun. With modern guns, often the beam focus electron lens and G2/G3/G4 anodes can be left alone because the cathode & G1 are mechanically separate and can be reached.
With older CRTs, for instance pre-War & early color tubes, the cathode & G1 are very close or sometimes even totally hidden inside the anode structure so dismantling of the entire gun is necessary.
In this case, the anodes & metal prongs used to mount them are carefully set aside to rebuild the gun in the precise same order once the filament and cathodes have been replaced with new ones.
I do not know how the glass bars are made originally. RACS does not make them, they re-use the originals with painstaking efforts not to break them.
In their parts inventory they have NOS glass bars and if one is broken, they find a substitute which matches in length, diameter and metal inserts. There is some leeway here, the metal inserts can be to some extent bent or tweaked to match the original, after all the glass bars are only for support and do not play an active role in the electron beam's creation.
Taking the gun apart and rebuilding it is achieved by using a small electric spot-welder with various size tips used depending on the size/weight of the electrode to be welded.
PS: Bob G. took photos and described his experience in removing the cathodes on 15GP22 CRTs. Bob, wanna pitch in?
François R. is justly proud of his engineering skills and describes gun rebuilding as a mix of science, technology, known to work recipes and a pinch of witchcraft. He quoted 16 to 20 man/hours of work to rebuild a 15G tricolor gun. He describes the 3D maze of wires connecting the 3 guns to the base as "an utter nightmare" to avoid accidental shorts when mounting the rebuilt gun to its new base/stem assembly.
Best Regards
jhalphen
Paris/France
Old 05-26-2013, 11:10 AM
Thank you Jerome. If you would, this project is of great interest to me, I would love it if you could post more of the knowledge you have of all things crt to this thread. There seems to be a lot that takes place between a few people, while there are many more who are not directly involved in the work, but would like to know more... like me.
I see what you mean about the heater cathodes on newer guns. I have a system 3 gun by zenith and it looks like the heater cathode is a quick change on that gun. I wonder if adding some of the newer gun's design ease to the older tubes will make for greater success when the guns have to be rebuilt on the old color tubes in particular....
I wonder if in the future the rebuilding will even require the reuse of the base, and the glass work will need to be rethought as well so as to accommodate new thinking for parts salvage when rebuilding tubes.
I think Scotty most likely had a source of new guns, and that you guys in France did a lot more intricate work. And worked on projects a lot closer to the impossible....
Thank you again!
Old 05-26-2013, 11:19 AM
Scotty used new guns, some of which required welding some added parts onto a basic gun. He did not do any cathode reconstruction or construction of guns from individual electrodes on glass mountings, as far as I know.
Old 05-26-2013, 11:24 AM
This question about guns makes me wonder if it is worthwhile to pursue a source of guns (if they haven't all dried up yet) and amass an inventory like the one Scotty had, under the assumption the rebuilding effort will be successful, but guns may not be available later.
Old 05-26-2013, 11:29 AM
My guess is that the entire rebuilding process will have to be rethought as time moves on. I had often wondered what it would be like to have to actually replace a heater and cathode. Or if a heater should be replaced, and the cathode scraped clean and new chemicals re-deposited.
Old 05-26-2013, 12:41 PM
I seem to recall, from IIRC a very long 60's in house RCA promotional film(or perhaps an episode of 'How it's Made') of what they did then, a scene of a monochrome electron gun being assembled where they stacked all the metal parts on a temporary alignment frame then applied the soft heated glass to the element tabs to hold all the elements together as opposed to welding the elements to tabs on the glass like RACS does.
This method might also be useful in gun rebuilding. If only the elements that need to be worked on can be melted off or out of the glass rods(or the rods cut and new glass melted on in the appropriate place with the new elements in position), and then melted back in it might be simpler than all that welding.
Old 05-26-2013, 02:43 PM
jhalphen's Avatar
Hello again to all,
@SquirrelBoy,
Thanks for your comments. What i have learned, is the result of a lifelong interest in CRT technology, reading many books such as Peter Keller's masterpiece "The Cathode Ray Tube", then from close contact with the RACS team over 6 years.
"A lot takes places between a few people": yes, gratitude and acknowledgment must be given to people who gave great dedication and invested a lot of $$ into CRT rebuild attempts such as John Folsom jr, Bob Galanter, John Yurkon, Steve McVoy who impulsed the entire ETF CRT rebuild project and the many UK/US/German/Dutch/Italian/French customers who trusted Hawkeye and RACS to bring alive again their vintage screens.
If hope is more alive today than before to make this project happen, these driven individuals must each be thanked for the years of behind the scene groundwork & experience done in the background.
The very fact that this new "CRT Rebuild Central" Forum now exists is a great achievement in itself.
"I wonder if adding some of the newer gun's design ease to the older tubes will make for greater success when the guns have to be rebuilt on the old color tubes in particular...."
Personally, i don't think so. This would entail a re-design of the electron optics design, a major task to say the least. Bear in mind that the original designs were conceived by teams of highly qualified engineers with ample funds and collective decades of experience in designing them. A new, simpler to build design would have to be compatible electrically with the original CRT's specs - a tall order to meet. Think about it, the people who had the knowledge are all in their 80s-90s today and in this day of digital flat screens, the art is on the teetering-edge of being lost.
"I wonder if in the future the rebuilding will even require the reuse of the base, and the glass work will need to be rethought as well so as to accommodate new thinking for parts salvage when rebuilding tubes."
A new base is mandatory for 3 main reasons:
- a stem is needed to mate to the vacuum pump assembly, and no, you cannot "reopen" a sealed stem.
- In the case of Pre-War CRTs, the glass used was Pyrex. Now you cannot fuse together Pyrex and post-War "soft glass" because the temperature gradients differ widely = 100% breakage certainty once the weld cools. When RACS rebuilds Pyrex Pre-War CRTs, an adaptor sheath is created using "Salami slices" of glasses of different gradients. One end is Pyrex, the other is Soft Glass to mate to the new Soft Glass base/stem assembly.
Soft, so-called "electronic glass" was developped during WWII and exclusively used afterwards to manufacture electron tubes and CRTs because it can be processed at lower temperatures and is much easier to produce by flowing into molds (volume production of millions of CRTs).
The very much increased coefficient of expansion vs Pyrex is no problem when the entire CRT/electron tube uses the same type of glass throughout.
"I think Scotty most likely had a source of new guns"
True, and so does RACS, several decades worth of inventory building + buyouts of NOS parts. The problem is that a given gun will only be compatible with one specific CRT model, and if you're lucky, maybe a few models in the same brand/product range. Most of these are compatible with fairly modern CRTs, spanning the 70s to the year 2000, in other words, our "oldies" B&W from the 30s, 50s, then early color 50s tubes are not within the NOS parts readily available so entire disassembly + rebuild is the only option.
Maybe in the future, TVs of the 60s to 90s will become collectable. This is not the case now, so these guns are pretty much useless. They will be recycled and in 20-30 years, they will be sorely missed.
"My guess is that the entire rebuilding process will have to be rethought as time moves on. I had often wondered what it would be like to have to actually replace a heater and cathode. Or if a heater should be replaced, and the cathode scraped clean and new chemicals re-deposited."
Heaters are replaced. Taking a filament out of the emissive cathode sheath is near impossible - it is wound, fragile and breaks.
BTW, concerning questions about rebuilding 2.5 Volt filaments ( Predicta CRTs) RACS found out that these are no longer manufactured. And for a reason: any +/- variation in wall supply AC power has a very significant impact on the electron emission of a gun powered under such a low AC supply. Therefore the gun is replaced with a 6.3 Volt filament and a transformer is supplied with the rebuilt CRT to convert 2.5V in the TV to 6.3 VAC.
In some rare cases of non-availability of new cathodes, RACS has re-coated the original part with a new electron-emissive coating with success (some Mil-specs impossible to find Radar tubes).
@Old_TV-Nut
Hi Wayne!
"This question about guns makes me wonder if it is worthwhile to pursue a source of guns (if they haven't all dried up yet) and amass an inventory like the one Scotty had, under the assumption the rebuilding effort will be successful, but guns may not be available later."
RACS would be happy if someone saved them, but who wants guns for 70s to year 2000 guns? - too young for our "heart of target" collectible TVs, but will be desirable 20-30 years from now. Who will be willing to pay for the storage cost for the next decades?
@Electronic_M
"This method might also be useful in gun rebuilding. If only the elements that need to be worked on can be melted off or out of the glass rods(or the rods cut and new glass melted on in the appropriate place with the new elements in position), and then melted back in it might be simpler than all that welding."
Glass close to its melting point is a very difficult media to work with: high temperatures, flames & gas nearby & oozy glass. Just ask Nick about his experience. Precise positioning and remaining in position while cooling of pieces of metal in a bar of glass with millimeter tolerances is no mean feat. I suspect that the OEM producers of the time had precision machinery and automatic alignment jigs that have long gone to the scrap heap heaven today.
Spot welding is relatively easy, the difficulty lies in getting the part precisely in position in 3D space and keeping it there while the weld is accomplished.
The days of the industrial giants such as RCA, Westinghouse, GE, Sylvania, Zenith-Rauland - their lavish multi-million $ production machinery are gone forever. We will have to make-do with modest equipment and a lot of elbow-work.
Best Regards
jhalphen
Paris/France
Old 05-26-2013, 07:00 PM
Well thank you again Jerome! And as I said before I hope more of this knowledge is made available for all of us to learn and carry as one of us may be the last ones with this special knowledge one day.
Have a good evening....
Old 05-26-2013, 11:03 PM
miniman82's Avatar
First Light: 1952-2011
And I got a mild dose of the works over there. Just listening to the stories about what it used to be like during the summer with both 5-bay ovens running, plus 5 more vertical lathes going with a guy at each of them... Can you imagine how hot it must have been?
I suppose it would be a good idea to have a rebuilding station climate controlled, at least in the area of the vertical lathe. That way you don't have to worry about cracking in cold air.
Evolution...
Old 05-27-2013, 02:48 AM
ppppenguin's Avatar
Jerome, thanks for a comprehensive reply to many of the points raised. The problems seem to split into 2 categories. Those which may be difficult but can be solved with craftsmanship and practice. And those that are a lot harder.
In the former are glassblowing skills, including the graded seals needed for Pyrex CRTs, Also the vacuum, baking and gettering techniques. These are all well known technologies, still in use for other purposes.
Things get a lot harder when replacement guns are not available. A spot welded gun can, in theory, be rebuilt using fairly simple equipment and a lot of skill. The gun of an EMI 6/6 was rebuilt this way in 1986. This is a complex hexode gun. It was rebuilt at Thorn-EMI Electron Tubes, now long gone, who specialised in photomultipliers. They certainly had the skills but not any specific jigs for that CRT. A gun assembly fused on to glass rods is more difficult. I don't know if a heater/cathode assembly can be replaced without dismantling the whole gun.
It strikes me that the hardest problem is when new heater/cathode assemblies cannot be obtained. As Jerome says, you can't remove and replace a heater from a cathode cylinder. Are h/k assemblies still available? At least they are small so storing them (in vacuo?) is not such a big problem. Making new cathodes with good emissivity and long life seems difficult. The knowhow for doing this must be almost lost.
I don't know anything about re-screening and aluminising.
Colour CRTs add a whole new set of problems.
I think others have mentioned an additional practical problem. We have a limited number of CRTs to use for learning the techniques. Each one is precious. When the original makers were making CRTs they could easily write off many CRTs as part of the development process.
It's a very brave venture. I wish all of you every succcess in keeping the craft alive.
Old 05-27-2013, 11:54 AM
jhalphen's Avatar
Hi to All,
Hello Jeffrey,
Thanks! for your message.
"The problems seem to split into 2 categories. Those which may be difficult but can be solved with craftsmanship and practice. And those that are a lot harder."
"In the former are glassblowing skills, including the graded seals needed for Pyrex CRTs, Also the vacuum, baking and gettering techniques. These are all well known technologies, still in use for other purposes."
RACS does not do glassblowing. From their days from working with Corning Glass (RACS's founder was originally a Senior Engineer at Corning) they've kept an assortment of NOS glass bulbs, alas mainly in the 8-10 inch sizes so no "big" bulbs to simulate 12 inch CRTs. I've asked them to keep this glassware while huge quantities of bulbs for 19 inch & above (90° to 110° deflection angle) went to the recycler.
When several of the Pyrex CRTs developped cracks around the EHT contact, i asked them to get a quote from SIVE to know what it would cost to make a master mold for instance for a 12BP4 bulb. SIVE is a Paris company which specializes in laboratory glassware and who are experts at working with Pyrex. From previous experience with SIVE, Philippe quoted around 2000 Euros for the mold, but i never saw a formal quote. The shallow insert of the EHT metal contact is difficult to do and would probably impact the price. If the demand was high enough, it would allow to make new "Repro" 12BP4s or any other tube in popular demand.
Personally, i do not relish the idea of a new Pyrex bulb, why not use much easier to process modern electronic glass. I guess the answer is that SIVE is a Pyrex specialist and they tend to stick with what they know. They are probably not the only glass molders/blowers to exist...
"Things get a lot harder when replacement guns are not available. A spot welded gun can, in theory, be rebuilt using fairly simple equipment and a lot of skill. The gun of an EMI 6/6 was rebuilt this way in 1986. This is a complex hexode gun. It was rebuilt at Thorn-EMI Electron Tubes, now long gone, who specialised in photomultipliers. They certainly had the skills but not any specific jigs for that CRT. A gun assembly fused on to glass rods is more difficult. I don't know if a heater/cathode assembly can be replaced without dismantling the whole gun."
You've pinpointed the problem: RACS has scores of new ready to install guns but most of these are for tubes of the 60s (a few), the 70s & 80s (a lot), so they are pretty useless for our specific vintage needs.
Still, having an inventory of parts allows "to be creative" when unforeseen difficulties happen with a rebuild. I remember François R. showing me a couple of UK tubes where gun parts had been grafted from a donor NOS gun because the original was too far gone to rebuild properly.
Once you master from scientific training + decades of experience the interactions between electron beam focussing, acceleration, deflection angles & EHT, yo can juggle the parameters to make it work.
"It strikes me that the hardest problem is when new heater/cathode assemblies cannot be obtained. As Jerome says, you can't remove and replace a heater from a cathode cylinder. Are h/k assemblies still available? At least they are small so storing them (in vacuo?) is not such a big problem. Making new cathodes with good emissivity and long life seems difficult. The knowhow for doing this must be almost lost."
RACS has a huge inventory of filaments/cathodes/heaters & getters. As for new production, it has really ground to a stop for consumer CRTs. There are still specialists producing parts for high power Broadcast tubes, particle accelerators used in physics - heavy use of Klystrons here, etc.
Actually over time, the industry of CRTs simplified the product range. Philippe told me that today there are only 2 sizes of cathodes, so it it quite possible to salvage NOS ones from much more recent guns if you need a part and have no inventory.
In their opinion, there might be suppliers of new parts in China and India, after all China and Russia produce today copies of favourite audio output tubes for the hi-fi market. The hitch is that with the company scaling down to near closure, they have no incentive to meet companies in faraway lands & assess the quality of unknown parts. Also, any order would have to be in high volume, probably on the order of a 1000 at least.
They also have experience in re-coating the electron-emissive paste when some really oddball tube occasionally came in. Think Mil-spec Radar/Sonar/Cockpit Display CRTs.
In a nutshell, you clean the entire CRT down to transparent glass, then you rebuild the entire screen assembly:
- wash out all phosphors, Dag, etc. - many wash cycles
- clean with a diluted mix of hydrofluoric acid.
- deposit new screen - a wet suspension
- tilt CRT, pump out excess liquid
- dry
- apply a layer of cellulose for adherence of the aluminum layer
- dry
- vacuum pump & sputter aluminum
- cook to evaporate the cellulose - nasty (flammable solvents here!)
- apply Aquadag to inside of tube - not easy
By then, the bulb assembly is now ready to receive its new or rebuilt gun.
Sme nuisances that can ruin your day:
- uneven screen coating - restart from scratch
- micro-roughness of the glass on the inside surface of the screen: leads to streaks once you light up the finished tube.
- Inside Aquadag too close to gun's end: EHT flashover.
"Colour CRTs add a whole new set of problems."
Gun wise, it's triple the amount of work. Screens are inspected prior to any work because if the phosphors are damaged, nothing can be done.
No rebuilder ever deposited colour screens. Only the OEM supplier had the lighthouse projection systems for depositing the phosphors.
"I think others have mentioned an additional practical problem. We have a limited number of CRTs to use for learning the techniques. Each one is precious. When the original makers were making CRTs they could easily write off many CRTs as part of the development process."
Very true. However practical experience could be gained from rebuilding cheap oscilloscope tubes such as 3PB1, 5BP1 of which there are still ample Mil supplies dating back to WWII.
Rebuilding these screens with P4 (B&W) phosphors would certainly make Pilot TV-37 owners happy.
One last piece of news about RACS: they are hoping for a Navy order of Radar/Sonar rebuilds. This would allow them to reactivate the screen coating line. As it hasn't been used in over 6 months, the entire plumbing must be flushed in formaldehyde and re-brought up to the stringents specs needed to ensure contaminant-free screen deposition.
"It's a very brave venture. I wish all of you every succcess in keeping the craft alive."
Thank you! we will need every help we can get.
Best Regards
jhalphen
Paris/France
Old 05-28-2013, 01:34 AM
ppppenguin's Avatar
Jerome, thanks again for a comprehensive reply. I think the meaning of the word "glassblowing" may have suffered in translation. Here in the UK it means a wide range of skills for working with glass, not just the actual blowing of a glass vessel. So fusing a new CRT neck on to the cone, sealing the pinch etc are all glassblowing. So is making a graded seal, though this requires much more skill.
I agree with you totally about not trying to make Pyrex CRTs from scratch. If you're going to attempt this you might as well make life easier by using soft glass. The cost of the moulds is a big problem if you only need a few CRTs.
A question about h/k assemblies. In the UK VRAT forum http://vintagetvandradio.myfreeforum.org/index.php the point was made that CRT cathodes emit from the end of the cathode cylinder but valve cathodes emit from the main body. This would make valve h/k assemblies unsuitable for CRTs. Do you know anyting about this?
Old 05-29-2013, 08:15 PM
miniman82's Avatar
'Valve' cathodes are completely different than those used in a CRT.
Evolution...
