Old 06-12-2013, 05:56 PM
The tv might not work with that glass thing broken off like that...
Old 06-12-2013, 06:16 PM
technicolor's Avatar
technicolor technicolor is offline
go big or go home
little squirrel boy told a joke, how cute.
Old 06-12-2013, 06:41 PM
yup......
Old 06-12-2013, 07:24 PM
go big or go home
Talking
yeah, that was a real knee slapper. I couldn't stop laughing.
Old 06-12-2013, 07:31 PM
Love keepin' ya entertained.....
Old 06-14-2013, 10:17 AM
Charlie's Avatar
Charlie Charlie is offline
On Land
Joe,
The convergence assembly in the pic hanging to the left of the broken neck... use some TLC with that. Those assemblies can sometimes be quite brittle and break. Also, considering the missing part of the neck, do you see the centering rings in there somewhere? There should be two rings with little tabs on a plastic piece that fit over the neck.
CTC-15's are typically pretty easy to work on. The worst part is installing all of those damn electrolytics... whether you're going to restuff the original cans, or just tuck new replacements under (and over) the chassis somewhere.
There are several threads in this forum regarding CTC-15's. It would be worth your time to read over some of them.
Good luck with your set.
Charlie Trahan
Old 06-15-2013, 12:03 AM
You will also need to find the blue lateral convergence magnet to get static convergence to work.
Old 06-15-2013, 07:52 AM
Charlie's Avatar
On Land
Yep, forgot about that one. If it didn't get ripped away, it should also be hanging by a blue wire that is typically soldered or clipped to the convergence board.
Charlie Trahan
Old 07-07-2013, 10:16 PM
go big or go home
can u post a picture of what i am looking for?
Old 07-09-2013, 06:51 PM
Charlie's Avatar
On Land
Sorry... no can do at the moment. I am on board ship heading into Puget Sound... far, far away from my sets. Won't be home again till September. I looked in my laptop, but don't have a good enough shot of the back of a color tube where all the goodies mount up.
The magnet is typically the last thing on a roundie tube... usually held on with a spring, and there is a ground wire on the spring bracket that connects to the chassis of the convergence board above.
I'm sure someone else here can snap a quick pic of what you need to look for.
Charlie Trahan
Old 07-09-2013, 07:27 PM
go big or go home
Thanks i appreciate it. sounds like i am missing something, there is nothing clipped to the convergence board
Old 07-09-2013, 08:25 PM
Charlie's Avatar
On Land
I kept digging, and finally found some shots from my Curtis Mathes. The magnet in question here is the item closest to the base cap... has a spring on the bottom, and the magnet is on the opposite side... that stick standing up with the blue ink on the end of it. Note the wire on the bracket... it will go up to the convergence board and clip on there... or soldered.
Charlie Trahan
Old 07-09-2013, 08:45 PM
sampson159's Avatar
sampson159
some have a wire soldered on it and some dont.doesnt matter,they are interchangable.purity rings.i have 1 or 2 i ll send you if you need one
Old 07-09-2013, 09:07 PM
go big or go home
Ron your a life saver and man;s man. A man who would not be afraid of a combo, no matter how large.
Old 08-15-2013, 12:11 AM
go big or go home
an update:.
Have the chassis out and going through it thoroughly, all three wax caps in this set were bad. And so far all three electrolytics were bad. Surprisingly, the one e cap, had a reading of 80uf, instead of the marked 50uf. I would assume when they got older they would drift lower.
My capitance meter is well worth the $16 i paid for it. Started yesterday checking resistors. ONmy digital multimeter, one reads 1, all all settings for ohms, does that mean it's shorted?
