Old 06-16-2013, 10:38 PM
portacolor CRT replacement video
thought someone may be interested in whats involved...
http://www.youtube.com/watch?v=wOmfzGaGfbg
and the finished product
http://www.youtube.com/watch?v=xmA086NflUE
Old 06-16-2013, 10:54 PM
zenith2134's Avatar
Very good video.
I put a NOS 11SP22 in my 1966 Portacolor a few years back.
It is now with me under the Atlantic Ocean.
cheers
Old 06-16-2013, 10:57 PM
the huricane/flood got it?
Old 06-16-2013, 11:03 PM
AVeturri AVeturri is offline
It got the entire collection save for the records and audio upstairs.
not sure I should even be here. carry on guys
.....AHA
Old 06-16-2013, 11:05 PM
sorry to hear about that...
Old 06-17-2013, 09:35 AM
[QUOTE=DaveWM;3072521]thought someone may be interested in whats involved...
I'm glad to see it turned out that well. The convergence looks good.
Were you able to get the purity perfect, as well?
P.S., you must be using an inside antenna with your DTV convertor. A lot of breaking up.
Old 06-17-2013, 09:54 AM
yep was able to get the purity and convergence just fine, I did a rough setup so I need to do again with a cross hatch, as I used an ota pic to setup the convergence. The box was on a simple indoor antenna, I should get it on a DVD to get a better pic. Thanks again!
Old 06-17-2013, 11:12 AM
Rod Beauvex Rod Beauvex is offline
The lead ear.
What was the movie you were watching in the second one?
Old 06-17-2013, 12:31 PM
Columbo was on "matter of honor" I think was the episode.
Old 06-17-2013, 01:30 PM
The lead ear.
I loved the totally flat "Anyway, that was a success" comment in the vid.
Does the bottom always have the circuit board exposed?
Old 06-17-2013, 01:43 PM
the cabinet back has a bottom part attached. when its completely put back together the bottom PCB is protected by a slotted cover. I have to work on the degauss switch, its not working reliably.
Old 06-17-2013, 01:50 PM
zenith2134's Avatar
Mine was the same model. Had a lot of trouble setting proper purity and convergence, although , as documented here in pictures someplace, I got it damn close. That was a space-heater in terms of radiated heat but it was quite a reliable GE and made a charming picture. Also ran into a case of the tun whiskers on the AGC potentiometer causing a white raster, Blew it out with 600VDC capacitors
Old 06-17-2013, 02:18 PM
this set is using only one of the convergence dynamic coils, the horz ones. the vert coils are not in (green directly to ground). I will have to get a good cross hatch to do a better job of it. It does have some tunable issues (somewhat tunable, I can't completely correct with fine tuning).
It looks sorta like a delay line issue in the chroma, the chroma seems to be shifted to the right a bit. De tune (fine tuner) and it look better (and the chroma gets weaker but easy to up the color to compensate). If you tune it to near sound bars like most set would be tuned the chroma goes into overload, and the colors tend to separate, the green lagging the most to ther right (separate horizontally that is). I have heard of delay line problems, but I am not sure that would account for the tunable issue, except for if the chroma gain increase in the IF pass band would some how make the delay worse. Also do not under stand why the green would the most effected (shifted the most to the right).
It certainly not a big deal as just detuning gets you almost there. My plan is to sweep the IF and take a look at it, but will not make any adjustments until I get some time with my BK 415 on some other sets.
Old 06-17-2013, 02:25 PM
ok looking a bit closer with the color all the way down, I can see a tunable cost in the luma as well.
Old 06-18-2013, 12:17 PM
If yours has the wood grained cabinet then it is identical to my Portacolor.
