I realize you've achieved your stated goal, but here are a few more tips on moving fragile things for future readers:
If you can move it in a passenger vehicle, the ride will be much smoother for your treasure. Minivan with the middle seats removed gives you secure, weatherproof storage with appropriate hold-down locations. Use non-elastic hold-downs if you're not resting the device on a cushion/absorber. So, if you're tied to the vehicle, make sure it can't move, and then "snap back" due to bungee cord elasticity. Better to be secured so there's no movement possible. If you are placing it on cushions, then bungees may be appropriate, if loaded correctly. If you're moving one small item in a truck that rides harshly, load it down with some other well-secured, heavy items. That way the suspension is more forgiving. Same with trailers -- a good load will help control bouncing and harsh impacts. And finally, like noted in earlier posts, spend most of your effort on controlling sudden deceleration movement. Second, side-to-side. And finally, movement due to acceleration. The last one is the one that's most in your control. Glad you arrived with minimal damage, and happy fixin'! Chip |
