Old 07-23-2013, 08:41 PM
Zenith6S321's Avatar
Zenith6S321 Zenith6S321 is offline
Well that little white vertical line, and my replacing lots of resistors in the RF and IF convinced me I should do a complete alignment of my set. Boy did that take a long time to do. But, I think I learned a lot, and got a good result. You be the judge. Here are some pictures starting with the final video waveform at the grid of the 1st video amp using a Sencore VA62 multiburst 10 bar sweep from 0 to 4.5 MHz in steps of .5 MHz. Next is the chroma sweep with the required 1st and 3rd bars the same size. Then the multiburst waveform at the green CRT grid with no color. Then the multiburst on the CRT showing a some discernable lines at 4 MHz (second bar from the right). Then color bars.
