Old 08-07-2013, 07:43 PM
TinCanAlley's Avatar
Originally Posted by Findm-Keepm View Post
I quite agree - when my dad retired back in 2008, he had exactly 7 good Zenith Duramodules and about 30 boxes marked with the symptoms the module had. After the heyday, and after junking a few sets, shops ended up with lots of questionable stuff.
As far as needing a transistor, post the 121- number, as many of us have stashes of original parts - yours for postage, in my case. Don't default to buying new stuff when we might have what you need, and are willing to give it away!
Cheers,
Thanks. The part # is: 121-755
I bought these off ebay and they were noted as being NOS. They sure don't look used and are a newer cream colored board instead of the old brownish (I'm so bad with any color other than primaries). The boards are the updated versions of the originals, but they can't be much newer as they also have plug in transistors.
Old 08-07-2013, 07:47 PM
rcaman's Avatar
rcaman rcaman is offline
looks like a capacitor has leaked on the traces. steve
Old 08-07-2013, 10:08 PM
Findm-Keepm's Avatar
Followin' the Rules...
Zenith may have had a second production run, as many shops ordered modules but failed to turn in duds. I remember PTS and others would issue a hotlist if modules they would buy at the dud price, to develop sufficient stock. Zenith System 3 modules were that way in the early 80s - some modules were backordered to the factory to get replacements. We fixed all of ours, so we never swapped anything but tuners and tuner controls. Duramodules (the Zenith term for your module) were exchanged, as the modules were cheap, and Time-to-repair was greater.
I'll check in the morning and see if I have your transistor.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 08-07-2013, 10:40 PM
Okay, the new boards aren't cream color (I was going from memory). They're actually white and green. Here's a pic of the one I installed. The bad transistor is the one with the screw hole just behind large orange capacitor.
Old 08-08-2013, 07:30 AM
so you still did not look into the horz blanking? that would have been the 1st place I would have checked.
Old 08-08-2013, 09:47 AM
Yes lets get back to the jail bars ! The filter can was a good learning
experience but as I suspected unneeded..............
The Sams is in front of me & I am redy to rock & roll !
Old 08-08-2013, 09:57 AM
is this the 25dc56? I assume so,
I would look at the diode and blanking transistor, as well as the voltage divider in front of that.
Scope the fly pulse all the way thru the two blanking transistors.
Old 08-08-2013, 11:12 AM
I'm doing the best I can. I'm new to this and am doing the things I can do/know how to do. If those don't work, then I can start to tackle the harder things. I don't own a scope, so I'll have to borrow one. I've read through the SM and don't fully understand how to test the blanking circuit, etc.
I'm willing to go all the way in testing an fixing you you're willing to help and understand I'm pretty new to all this.
My first fix is to undo something I just did. If this problem sounds familiar, yell. After changing the horizontal board and caps, I now have a strange effect on the screen. It's hard to explain, but I think if you've seen it before, you'll understand. There are invisible waves rolling diagonally across the screen towards the upper left corner for a moment. They then stop and reverse direction rolling down towards the lower left. They stop again and reverse. The closest I can give an example of is when you're adjusting the APC to get the movement out of the color bars, except these aren't colors rolling, just invisible waves. I'm not sure if it's the what I did, or some other interference that's being introduced.
The chassis is the 25EC58 and if you want to point to things to test/replace, please fire away!
Thanks!
Old 08-08-2013, 04:05 PM
Sorry, I don't have one. I go from 121-500 to 121-758, nothing in between.
Cheers,
Brian
Old 08-08-2013, 07:01 PM
Cheers,
No problem. Just found out there's an old electronics shop a few miles from me that has lots of older stuff sitting around. I'm going to make a list of parts and call to see if they have them.
