good luck with it I hope it fixes the problem. Try the transistor 1st as its just a plug in IIRC.
oh and if it was me I would prob just j hook in those parts to avoid stress on other stuff. I am pretty sure the diode is silicon but I would put a heat sink on it any way.
Do yourself a favor, check the NOS parts before installing thats the diode and transistor. |
You read my mind. I have the transistor in front of me and am about to test it. If it tests okay, it goes in and I fire her up. If that doesn't help, I flip her over and start the resistors and diodes.
Pioneer SX-1080, Pioneer PL-115D, Pioneer CT-F9191, Pioneer RG-1, Wollensak 8050A, Akai 4000DS MkII, Pioneer CS-05 & Polk 1.2TL Denon 5803A, Pioneer DVL-700, Pioneer CT-W603RS, Toshiba HD-A3, D-Link DSM-520, Dish VIP-722, Polk 1.2TL, CSi5, LS/fx, RT-800 and PSW-650 |
![]() BtW, does your schematic give you voltage readings for that transistor? if so it would not hurt to check them. Make sure you check the notes regarding without signal, line voltage etc... Be VERY careful reading voltage with SS parts, a slip of a prob can instantly destroy a diode or transistor. Last edited by DaveWM; 08-19-2013 at 01:26 PM. |
I realize I put this thread in the wrong forum. How do I move it?
BTW no need to replace anything but the Blanking transistor the others would not account for the jail bars (at least should not). Don't make too many changes or substitutes. You want to try and diagnose the problem and not shot gun parts at it. If the diode/ blanking transistor/cap/resistors to not resolve it then you are into tough dog territory, and you need someone that has a scope and some real talent to fix it. I only hope that the target parts are it, again its really just an educated guess. |
I'm going to do the testing.
Pioneer SX-1080, Pioneer PL-115D, Pioneer CT-F9191, Pioneer RG-1, Wollensak 8050A, Akai 4000DS MkII, Pioneer CS-05 & Polk 1.2TL Denon 5803A, Pioneer DVL-700, Pioneer CT-W603RS, Toshiba HD-A3, D-Link DSM-520, Dish VIP-722, Polk 1.2TL, CSi5, LS/fx, RT-800 and PSW-650 Last edited by TinCanAlley; 08-19-2013 at 04:29 PM. |
Okay, after a total brain fart and leaving the positive lead in the OHM connection, I finally have the numbers.
For the blanking transistor I got 6.8V for the Emitter (SM has 7.19V), Base was 3.9V (SM has 4.43V) and the Collector as 23.4V (SM has 23.5V).
the sams should id the pins of the existing trans or you can look a the schematic to figure it out. then you need to look at the replacement and check the package for what pins are what.
