Old 08-19-2013, 04:24 PM
If you feel you need to replace all the caps because the set is from 1953 or something, then it is very smart to replace just a few, power supply first, then run the set with the chassis in the set and the back on. Run it for a week regularly, if everything seems stable, do more. Be sure new parts are at least rated proper tolerance, temperature, and voltage ratings... Same as original or better.
If a problem pops up, you need to fix it before you do more.....
