Old 08-15-2013, 06:50 PM
Dave A's Avatar
Dave A Dave A is offline
Philco Portacolor
Snagged this from the bay. Badged as a Philco T5062WA and likened to a Portacolor of the day. Did not know Philco farmed this out. Seller photos for now until it arrives. Does the chassis look like a GE?
Seller says "It is a GE manufactured 11 inch PortaColor, similar to the GE H-2, badged to be sold as a small screen Philco color TV. “T” designates Philco 1969-70 model years.
My Portacolors are long gone and I am returning to the fold except for one sorry example which could be a CRT donor. Stripe tube.
File Type: jpg $(KGrHqEOKpIFH,GoeEO4BR+DOrr5eQ~~60_3.jpg (55.4 KB, 112 views)
File Type: jpg $(KGrHqFHJEgFHVP8,Lr0BR+DOsKbw!~~60_3.jpg (62.4 KB, 92 views)
Old 08-15-2013, 07:16 PM
cool, and you have columbo playing .... very macho.
http://www.youtube.com/watch?v=xmA086NflUE
skip to about 2:08
Old 08-15-2013, 07:58 PM
egrand
Guest
Posts: n/a
I saw that listed and I'm glad somebody here got it. Hope you post some more pics when you get it.
I was more surprised that GE made a porta color for somebody else. I read they had trouble keeping up with demand, so it's interesting they took the time to run some off for Philco.
Old 08-15-2013, 08:34 PM
sampson159's Avatar
sampson159
saw only one of these.oddballs and really good performers.i actually liked all the philco sets.the 25v crt was a really fine performer.they made very good electronics while under ford.
Old 08-15-2013, 09:37 PM
They also built some for other private label makes.
Packard bell, or????.
I had a Toshiba built, 16" hybrid Philco, ca 1969.
Old 08-15-2013, 10:38 PM
rca2000's Avatar
rca2000 rca2000 is offline
skip to about 2:08
Episode is "A matter of Honor".
Old 08-16-2013, 12:22 AM
I've seen one Packard-Bell branded porta-color. During the early '70's, PB used GE as a supplier of many of their TV's. Somewhere around here, I have a 19" C2 chassis GE and a 15" SE chassis B&W that are both Packard-Bell branded TV's.
I've also seen the GE porta-color under the Truetone (Western Auto) brand.
Old 08-16-2013, 08:23 AM
I thought the same thing about the Truetone, but couldn't prove it!
I also saw GE sourced Bradfords , Wards Airlines and Sears sets, but not Porta-colors.
Old 08-16-2013, 10:37 AM
GE also sourced some JC Penney TV's; but, I don't know if there ever was a Penncrest/JC Penney porta-color.
Old 08-16-2013, 11:11 AM
jstout66 jstout66 is offline
I remember ONE "Truetone" Porta-color that came in (quite often) for repair in our shop. God that thing was a DOG. Not that Porta-Colors were anything to write home about, but having that Trutone name slapped on must have really doomed it. Kind of off topic, but we had a Western Auto in our town, and got stuck doing the repairs on the "Truetone" items. It seemed like EVERYTHING electronic out of that store was JUNK.
Old 08-17-2013, 12:50 AM
Dave A's Avatar
It arrived in fine shape and I have several cubic feet of pellets left over.
Powered up just fine. The CRT is tired but useable. Pic gently blooms up and down with the brightness control. A quick screen/drive adjustment gave a good pic. AGC adjustment helped a bit. Focus is dull. Red convergence needs a touch-up.
A complete tube change should help. Need Sams 1032-2 to see if this one has the focus terminals. DC resto is still missing on this one. Color adjustment has enough for several sets. All as I remember with Portacolors.
The only problem is the tint control. Pic is just a bit off on the green side and the control does nothing other than shifting the color to the right like a delay-line control at one end of the control.
Pics upload not working right now. Will try to edit tomorrow.
But the cat likes it as a warm place to sleep. All is well.
Old 08-17-2013, 07:45 AM
does it use the Vari cap or pot for tint?
I had some issues with on off my pc's vector scope was usd to confirm a gated color bar pattern. I needed to tweek up a couple of the transformers in the color demod (in my case I did not have good green at the grid of the crt).
The color delay on some of my is a problem too, as you advance the fine tuning you can see the three colors actually split apart and shift to the right. I end up detuning to bring in color the best. That being said the color is way over saturated when tuned normally, so I was thinking maybe the chroma is too far up the IF slope. My goal is to check out the alignment on one of these in the near future as I get more exp with my BK 415.
I don't recall the tint control effecting the right shift but think I will give it a try now that you mentioned it.
Old 08-21-2013, 12:48 PM
Findm-Keepm's Avatar
Followin' the Rules...
Like most Portacolors, it's taps - pin 9 of the tube connects to either Ground, 270V B+, or Boost (675V) for focus. You'll find a 1 Meg or a 560K in series with Pin 9 - that's the tap resistor.
PM me if you need the Sams.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 08-21-2013, 01:00 PM
Also, don't forget the big white Elmenco bomb - the .1uF white cap behind the AGC pot - they spew foil when they go.
Cheers,
Brian
