Old 09-04-2013, 05:31 PM
So if that 21cyp22 that had the neck broke off was to have enough of the neck left as if it were going through a rebuilding process, could that tube be used for a rebuild test if it were for now sealed, and vacuumed to prevent any further damage from the air...?
After all, there will need to be some "test tubes" getting the rebuild process down right.... right....?
I think Technicolor has a tube cut off about the same point as this one.... 2 test tubes...?
Yah, they may not work bla bla bla but you gunna try a new process on a something you can't replace......?
