Old 09-12-2013, 07:55 AM
Kiwick's Avatar
Kiwick Kiwick is offline
slave to 3 equines
Dumont RA-400
Hi,
i recently found this Dumont RA-400 set on the curb, it's in poor conditions with peeling veneer and a lot of missing tubes, but the CRT is still intact and it seems to be a low hour set judging on how clean the HV cage is inside.
This set was made for the Italian market and was apparently assembled in Italy using italian-made components and has Philips speakers in a separate bass reflex compartment, it also has a voltage selector to enable it to be used on 120,160,220 and 240v power.
is this a clone of an american Dumont set?
Old 09-12-2013, 08:58 AM
Originally Posted by Kiwick View Post
Hi,
It sure looks like the last of the Dumont sets, that were built here.
They had a separate power chassis. Also, the control panel is very similar.
Old 09-12-2013, 10:09 AM
Kiwick's Avatar
slave to 3 equines
we apparently had Dumont sets built here in Italy until about 1972, the last ones had a cheapish 7-tube hybrid chassis
this one has "high fidelity" written on the CRT bezel, a few knobs hiddend behind a metal door on the front panel, and a "dumonitor" control behind.
maybe someone has a tube placement chart for this set? mine is missing about 2/3 of them
Old 09-12-2013, 10:52 AM
Your set might use the European type tubes, that many of the American sets, didn't use.
The USA Dumonts used 6BZ6's in the IF, video out would a 6AW8 or a 12BY7, horiz out would be a 6DQ6, damper, a 6DE4.
Dumonitor is an AGC or a noise gate control. A great performing set!
Old 09-12-2013, 03:51 PM
Kiwick's Avatar
slave to 3 equines
this one uses american type tubes, the later hybrid dumont sets used european tubes instead
Old 09-12-2013, 04:03 PM
Looks like they went to some effort to minimize the impact of stray magnetic field from the power transformer, from the angle the transformer is mounted on that chassis.
Old 09-14-2013, 09:31 AM
Hi,
I pulled the Sams on the RA400, dated 7/58. Your set looks identical.
Was the TV system used in Italy, at the time the set was built, referred to as CCIR?
Also, where did they use 160 volts?
Old 09-25-2013, 08:35 AM
Kiwick's Avatar
slave to 3 equines
we had CCIR-B TV broadcasts in Italy indeed
http://en.wikipedia.org/wiki/CCIR_System_B
depending on the area and power company, we had 110, 125, 160 and 220v power here in Italy until the nationalisation of all power companies into the Enel state power company in 1962,
but some rural areas continued to use these oddball voltages up to the early 70s until all old utility transformers were replaced, some remote areas even had DC power from small hydro plants
also the line voltage was quite unstable back then so most people had to use saturated core reactors to power their TVs.
