Old 09-24-2013, 04:16 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Flickering '87 Trinitron
It has done this seemingly at random since I got it, but I have since found out it is probably caused by power fluctuations. I was running the dishwasher while watching a movie the other day and noticed that the flickering, a white horizontal line at random places on the screen, would happen when the dishwasher would switch to different cycles. I'm wondering what's going on inside the set that might be contributing to this.
Old 09-24-2013, 04:40 PM
Could be poor voltage regulation. Check the power supply and the caps associated with it.
Old 09-24-2013, 07:56 PM
Findm-Keepm's Avatar
Followin' the Rules...
Sonys of that vintage also had bad solder joints in the IF section - but the flickering would be sensitive to a tap on the cabinet of the set. What's the model number? Is it an XBR set, or earlier?
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 09-24-2013, 08:04 PM
This one may remain a mystery but.
It may be supply regulation but usually you would see the pix
kinda pulse. Other heavy hitters would cause it also like
the fridge, washer, well pump etc. Is it on the same line
as the DW ??
Another likely thing is the DW is transmitting some noise or
hash through the line or over air. More likely if the DW is
electronic. If thats the case it may be kinda normal.
Try listening on an AM radio for a static crash when it happens.
Third thing is Sony had lots of bad PC cons in the tuners &
IF's but that would be shock sensitive. Try hitting it & see
if it does it.
Old 09-24-2013, 08:11 PM
Jon A.'s Avatar
Huh? I can't really get into actually fixing this stuff without the tools I need, and they get expensive when they can be found here, which isn't often. I don't have equipment money to toss around like TinCanAlley. Right now I'm just curious. By the way, hitting the cabinet does not produce the same effect, and the dishwasher is on a separate line.
Old 09-24-2013, 08:19 PM
In the same house? Then they are on the same line. Branch circuits in a household WILL share EMI, noise, and power surges/droops. What's the model number of the Sony? Sony has some sets with massive AC filtering through common mode chokes and capacitive filter, and some with little filtering (mostly portables, for weight sake) - hence the need for a model number.
Cheers,
Brian
Old 09-24-2013, 08:23 PM
Jon A.'s Avatar
Apartment actually, a house is another thing I don't have the cash for. The model number is my username. It's the set that started my collection.
Old 09-24-2013, 08:48 PM
A suggestion - get an external EMI filter, as you can't do much with the dishwasher. TDK makes an excellent one - ANF-105 (max 5 Amp) or the 106 (max 6 Amp). I have two, scrounged after my office did away with a beast Ricoh copier/printer that gave all the CRT monitors fits when running. I use them on an older plasma set that is susceptible to EMI from a crappy cable box, and the other is on my router/modem, a problem rooted out when a temporary roommate ( a real geek) pointed out some packet problems that I still don't comprehend.
Attached is the only entries I could find for repair tips for the 1926R. Your set is one of those affected by the bad solder in the IF sections.
Cheers,
Brian
Old 09-25-2013, 10:13 PM
duckland 23's Avatar
duckland 23 duckland 23 is offline
My sony television was giving me lines from my directv box . It comes and go's now . The directv guy changed the LMB AND redid the connections for the coax cable . Im betting you have a bad cable . The lines are sideways right and about a half a inch apart right . First off youi have cable or satellite directv or dish ?.
Old 09-25-2013, 10:25 PM
Jon A.'s Avatar
Neither, I was using my DVD player through an RF modulator. No cable or antenna here. Sideways lines? I don't understand. They are horizontal and appear in random places for a split second, making the rest of the picture jump a bit as well.
