Old 09-25-2013, 03:19 PM
Need Horz osc transformer for Olympic tv - any cross references?
Sams does not list any although it is on the part inside the set (set 85 folder 10) sets before this used the same part (67-15) , it is listed in those part lists and even earlier, the part number is TR-1475-1 or TR-1475 , anyone have alternate manufacturer numbers like merit or stancor or thordarson ?
maybe someone has a junk set that I can take the part from ? the 10" and 12" sets all used this part , they even have pretty much the same chassis
mike
Old 09-25-2013, 03:35 PM
John Folsom's Avatar
What is the model number fo your Olympic TV? Thordarson lists two replacement part numbers, HS-3 and HS-2, depending on the model number.
John Folsom
Old 09-25-2013, 03:44 PM
Tim's Avatar
Tim Tim is offline
The Merit sub for both part numbers is TV-161.
Playthings of the Past shows 1 in stock.
http://www.oldradioparts.com/2a6fla.txt
Tim
Old 09-26-2013, 01:11 AM
the model number is TV-950
Thanks
MIKE
