Old 10-19-2013, 11:57 AM
Console User Console User is offline
CRT Tube Numbers
Does anyone know what the following CRT Numbers are for and if either one of them would interchange for an A63ADG31X that my Zenith Console has in it?
1. A63AAM11X
2. A63AAYOOX
Old 10-20-2013, 12:01 PM
kx250rider's Avatar
REAL TVs have TUBES!
What matters most, is the yoke number (if they have bonded yokes), and CRT socket, and of course the mounting tab setback. Chances are they're swappable, but that's not a guarantee unless you verify the socket pinout, etc. Assuming the yoke is either the same, or is not bonded, AND ASSUMING you verify the socket pinout is the same, you could try hooking up your chassis to the other tube(s) and see if it works. If the focus voltage, or G1 is different, nothing should blow... Just won't work.
Charles
