Old 10-22-2013, 09:05 PM
Tube Radio's Avatar
Tube Radio Tube Radio is offline
Scope question
I have a question about a DuMont 304H scope that has a 5ADP1 CRT installed in it.
Up until about 5 years ago the scope (mostly restored) worked great and the CRT always focused properly.
One day while using the scope to watch TV (required two pother scopes to do that) the picture got out of focus.
When displaying a trace the focus control now has to be nearly full CCW for proper focus, but when displaying a waveform the focus control has to be at least 3/4 CW to somewhat resemble proper focus (never focuses as sharp as it does when just displaying a trace) which I know is not right.
I've tried another 5ADP1, a 5ADP2 and two 5ADP5 CRTs and all have the same problem. I even got another 304H scope with a 5CP1A CRT installed and tried the 5ADP* CRTs in it with the same problem while the 5CP1A CRT works properly in my original 304H.
On another forum I have had at least two topics over the years and have one going now without any answer as to why I have this problem.
I cannot use a 5CP1 CRT as I did use this scope at times to measure waveforms.
Main system
Scott LK-72A amp & LT-110 tuner
Garrard Zero 100C turntable
AKAI GX 255 RTR
iPod & computer
DIY speakers (upgrading them soon)
Old 10-23-2013, 12:19 AM
bob91343 bob91343 is offline
Apparently there is a problem in the potentials supplied to the tube. Compare them on the good and bad units and you will track it down easily.
Old 10-23-2013, 01:18 PM
6GH8cowboy 6GH8cowboy is offline
Been my experience with most scope fails in the past that the HV caps cause a lot of grief for focus, brite, etc..
I'm not familliar with this scope but if it is an old one, the caps cost more than the scope is worth. Often oil filled, 2kv or better...cha ching$.
Comparing voltages is a good idea, just be VERY careful.
Old 10-23-2013, 01:49 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
I agree, I would be looking at the various CRT gun potentials, and comparing them to the schematic or the CRT datasheets. Is the 5ADPx even a valid sub for a 5CPx?
The DuMont 304 was one of the first scopes I ever played around with. They were probably DuMont's best selling scope, and a pretty rudimentary circuit to repair. Check the HV caps for leakage, and the 2X2 tubes. Check the divider resistors in the focus/intensity control circuits, and replace any that are out of tolerance.
Be VERY careful measuring HV potentials in this circuit. The voltages are lower than a typical TV, but the 60Hz supply is capable of delivering a lot more current.
Old 10-23-2013, 03:22 PM
Tube Radio's Avatar
Here's the voltage readings I took back in 2009
Meter negative connected to cathode of CRT.
Anode 3
Maximum intensity +2.94 KV
Minimum intensity +2.89 KV
Anode 2
Maximum intensity +1.542 KV
Minimum intensity +1.504 KV
Intensity control adjusted to where image just appears on CRT
Anode 2 voltage + 1.597 KV
Anode 1
Intensity minimum
Focus control fully CCW +500 V
Focus control fully CW +253 V
Intensity maximum
Focus control fully CCW +592 V
Focus control fully CW +356 V
The 5ADP1 CRT was working in the scope when I restored it and there's no telling how many decades the CRT has been in that scope.
Main reason I don't understand this is because the scope is fine as the 5CP1A CRT focuses properly, but the few 5ADP* series CRTS don't. Same exact thing happens in the unrestored scope.
Main system
AKAI GX 255 RTR
iPod & computer
Old 10-23-2013, 04:55 PM
Wait - you have me confused. I thought one 'scope malfunctioned regardless of which CRT you used, and all CRTs work fine in other 'scopes. Now you say something else.
I also started my 'scope career with a Dumont 304A. Then I "upgraded" to a 401. Once I got my hands on Tektronix I never looked back. I had several 545s and 535s and a delightful 547 and a Fairchild clone. Now I have four Tek and one HP, all solid state. One of the Teks is surplus to my needs so let me know if you are interested.
Old 10-23-2013, 05:34 PM
N2IXK's Avatar
Technohippie
Comparing the datasheets for the 5ADP- and 5CP- shows MULTIPLE differences in required element voltages. The 5CP- uses a post-accelerating electrode, while the 5ADP- doesn't. They ARE NOT the same tube, or even close substitutes for each other. I can't see how a single scope could ever accommodate both tube types. The differences are just too great. Are you just leaving the accelerating anode lead hanging loose when installing the 5ADP-?
According to the manual I have here, the 304H is designed for a 5CP- type tube. The "H" designates High Brightness, thanks to the post accelerator. You need a 5CP- tube. Fortunately, they are VERY common, and relatively cheap. Here's one for $25 Buy-It-Now:
http://www.ebay.com/itm/Vintage-RCA-...item1c37c1489e
Old 10-23-2013, 06:22 PM
Tube Radio's Avatar
the 5ADP* series of CRTs do have a post accelerator and are the CRTs which don't work right in either scope. the 5CP1A CRT does work right in both scopes.
the restored 304H had the 5ADP1 CRT in it when I got the scope and did indeed work great with proper focus.
I'm beginning to wonder if there is am inherent problem with the 5ADP* series of CRT that shows up with age which if so could maybe account for why there are not many of those CRTs around.
Main system
AKAI GX 255 RTR
iPod & computer
Old 10-23-2013, 06:24 PM
Tube Radio's Avatar
what model Tek is the surplus one and how heavy is it?
Main system
AKAI GX 255 RTR
iPod & computer
Old 10-23-2013, 07:01 PM
N2IXK's Avatar
Technohippie
Originally Posted by Tube Radio View Post
the 5ADP* series of CRTs do have a post accelerator.
Yes, you are right. Looking at the wrong outline diagram in my datasheet.
But the voltages are still somewhat different. Perhaps the 5ADP- that you say was once working was actually a somewhat worn-out tube that was subbed in sometime previously, and the weakened characteristics allowed it to focus properly with 5CP- voltages applied. Then you replaced it with GOOD 5ADP-types which will not.
Old 10-23-2013, 07:07 PM
Tube Radio's Avatar
best I can tell the scope always had the 5ADP1 CRT installed.
I've even tried a well worn 5ADP5 which has light burn marks where the trace was for years in whatever the CRT came from and it didn't focus right either.
I cannot seem to find anything about the 5ADP* series of CRT except some for sale and datasheets.
Main system
AKAI GX 255 RTR
iPod & computer
Old 10-23-2013, 07:22 PM
N2IXK's Avatar
Technohippie
I have a 304H manual here in my library, it shows a 5CP-
The 2 304H scopes I have worked on in the past both used 5CP- tubes.
I have a Rider Encyclopedia on Oscilloscopes, and the 304H schematic shows a 5CP-
A Google search for DuMont 304H schematics shows 2 separate copies of the schematic, both showing 5CP- tubes.
I can't find a single reference to a 5ADP- in a 304H, besides your posts about this on various forums over the years.
All this would lead one to believe that the 5ADP- is NOT original to your scope, and coupled with the differences in gun voltage requirements and the fact that your scope works properly when you try a 5CP- in it would seem to make the conclusion obvious.
Old 10-23-2013, 08:35 PM
Tube Radio's Avatar
only thing I can figure is judging by the warning sticker about not measuring line voltage the scope came from the local air force base where I work which may explain the 5ADP1 CRT given the inherent issues a non flat faced tube has with distorting the displayed waveform.
also the 5ADP1 CRT worked properly for how ever long it was in there until the focus messed up. when I got it I used it maybe 3-4 years before the focus problem happened and it always had proper focus.
I am begoning to suspect it is some defect with the CRT that maybe shows itself with age. only way to be sure is with a CRT tester or even better something designed for that CRT.
Main system
AKAI GX 255 RTR
iPod & computer
Old 10-23-2013, 09:03 PM
N2IXK's Avatar
Technohippie
Heathkit made a 5MHz "Professional Oscilloscope" model OP-1 that used a 5ADP- tube, IIRC. Styled to somewhat resemble a Tektronix unit of the era. One of their best tube scopes, IMO.
Not a very common model, though.
Old 10-23-2013, 09:10 PM
Tube Radio's Avatar
one thing I just remembered is I can connect another 5ADP* series CRT in parallel with the one in the scope and the focus then works correctly.
Main system
AKAI GX 255 RTR
iPod & computer
