AM overload problem solved; FM sensitivity improved 100%
I found the trouble, I think. I was trying to get the AM dial calibration to track across the band, and was able to do so for all local stations in Cleveland, although the tracking from about 800 down to 550 kHz is still off. As a nice bonus (I wasn't expecting this), once I got the tracking where it should be for the area's local stations (there are no Cleveland stations below 850, so I'm not concerned that the dial calibration is still off in that part of the broadcast band), I put the radio back in its normal location on the dresser in my bedroom, and--to my surprise--the distortion I had been hearing on the local station on 1460 was gone. The station was (and is) now perfectly listenable on this radio, as it should be.
I also corrected a problem with low sensitivity on the FM band I had been having for some time; charging the batteries and operating the radio on AC using the wall wart transformer did not help. I was trying to tweak the alignment just a bit, on the chance that it might be off; well, while adjusting one of the trimmers, I pressed down just a bit, and a local station I had had the radio set to suddenly blared out of the speaker. I tuned across the rest of the FM dial and heard almost every major FM station in Cleveland (even a low-power NPR translator at 89.1 MHz), some stations coming in reasonably well even with the FM antenna stored in the handle (all solid-state Trans-Oceanics, until the R-7000 series, had the FM/SW Waverod antenna mounted in the cabinet handle; to use this antenna, one pressed a latch on the right side of the handle assembly to release the antenna so that it could be raised to a vertical position, after which the Waverod could be extended to its full length). With the Waverod antenna extended, the sensitivity of this radio is incredible. I was getting just about every FM station in Cleveland, plus a couple of out-of-town ones, which is more than I can say for the set for most of the time after I won it in an eBay auction this past summer. That is, I was getting most local stations, but they were quite weak, requiring the volume control to be almost fully clockwise before I could hear much of anything. After correcting the problem with the loose connection on the trimmer capacitor, however, all stations now come in with reasonable volume and are listenable with volume to spare. Turns out there is nothing wrong with the radio's AVC or AGC systems. As I said in regard to my C-845 after reconnecting the AM loop and restoring reception, it is nothing short of amazing, the problems one little intermittent connection can cause. I actually don't know what connection I restored in my T/O to get the FM singing loudly as it should have all along (and restoring the FM sensitivity), but I'm not complaining and will not question it. The set works now as well as it should (better, actually, as I was listening to an FM station about an hour ago some 50+ miles distant with excellent sound quality), and that's all that matters to me. I remember reading somewhere (I think it was on the T/O 3000-1 page of Radiomuseum.org) that the TO 3000 was not built to be very sensitive on FM, being one of the first (if not the first) portable transistor radios to have FM coverage. Well, I think I may have found at least one way to improve the set's sensitivity on this band; at least it worked on mine, but as I said, I have no idea what I did other than to press down slightly on one of the FM trimmer capacitors. Since this radio was built on a metal chassis and has no PC boards anywhere, the poor connection may have been nothing more than slight corrosion on one or both terminals of the trimmer capacitor in question; pressing down on the trimmer may have broken through the corrosion, restoring the connection. I wish to express my thanks to everyone who replied to this thread, and for all the tips and hints. I may eventually print out those replies and file them so I can refer to them if, heaven forbid, the local station distortion problem should return; I'm not expecting it to, but in a 47-year-old radio you can never tell.
Glad you got it sorted. Funny how the signal can jump all the way from Cleveland to your house, but can't jump that microinch of bad connection.
![]() A nice T.O. is on my must-get list... Chip |
The T/O 7000 series are also good radios, but only the first ones in the series were US made. The 7000s made near the end of the radio's production run were built offshore, and may not be of the same quality as the American-made ones; it is for this reason that I recommend you look for an early model R-7000 if you want a newer set. One word of caution if you go on eBay looking for a T/O of any type: Bidding can (and often does) get fierce near the end of the auction, with the winning bid often being quite a bit higher than the opening one. Be careful when bidding as well, as it is all too easy to put a bid on an item only to be outbid almost immediately. EBay is arranged so that the highest bidder at any given time will retain that status (the site is set up to automatically bid on your behalf up to your maximum bid), but once the system reaches your maximum bid, you will have to enter further bids manually; this is where a lot of auctions are lost. (I lost an auction for an R-7000 this way. ) Good luck. As has been said by others, the T/O 3000 and its variants are very good radios, and you will enjoy it; I'm enjoying the heck out of mine, especially since clearing up the AM overload and FM sensitivity problems. Zenith did not skimp on anything when they designed and built these sets; since they were built on steel chassis with socketed transistors (again, until the last R-7000s), they are sturdy and solidly built, but they weigh the proverbial ton, even without batteries. If you get one of the 3000s or the 1000 series (Royal 1000 and 1000-D, the latter having an AC adapter jack), you will have a radio you can be proud of. The T/O 3000s are noted, however, for two problems, as I read on Radiomuseum.org's site recently: one, the sets have a tendency to rattle at high volume levels (due to two strips of double-sided tape holding the speaker baffle to the inside front panel of the radio drying out and falling off after years of use), and, as I noted above, low sensitivity on the FM broadcast band. The latter is due to the fact that the T/O 3000 was one of the first portable transistor radios with FM coverage. I was able to increase dramatically the FM sensitivity of my own 3000 by adjusting a trimmer capacitor, but I wouldn't expect this dodge to work on all such radios. Many times low sensitivity is simply the nature of the beast (early FM radios were notorious for this problem, requiring external antennas in many cases to get decent reception, even in good signal areas); when the T/O 3000 was new, FM radio in the US was in its infancy, with little if anything to listen to if you heard anything on your set; in fact, most early FM stations (until automation equipment became plentiful and affordable, allowing stations to program so-called "elevator music" until they could see their way clear to hire DJs for live broadcasts) simply rebroadcast the programming of a local AM station. Most FM stations in the '60s were located in major cities, so you had to be in or near (very near) one of these areas to hear much of anything on your FM radio. The log book that came with my T/O 3000 has FM station listings that were current at the time (1966, when my set was built); this listing showed very few suburban FM stations, most all of the listings being for stations in major cities. Today, many of these listings are incorrect due to stations changing call signs (because of ownership and/or format changes) and in some cases frequencies, with some listed stations now off the air for good due to financial difficulties or other problems, and of course new FMs went on the air as time progressed, many such stations being established in suburbs of large cities or outlying areas. There were no stations below 92 MHz listed, however, since non-commercial FM stations (college, university, etc.) probably did not appear in the US until probably the very late 1960s or seventies. In my own area near Cleveland, this listing omits several non-commercial stations that in fact were on the air in 1966 and have been on, in some cases, since 1950 (there are at least two such stations in Cleveland, one of which is a non-commercial religious broadcaster; most other FM stations in this area, and probably in most major US cities as well, rebroadcast local AMs in the '60s through the mid-seventies and, in many cases, carried the call sign of the station they were simulcasting).
Jeff, WB8NHV Collecting, restoring and enjoying vintage Zenith radios since 2002 Zenith. Gone, but not forgotten. Last edited by Jeffhs; 11-04-2013 at 02:38 PM. |
A little heads-up if you're using batteries.. on my 3000, the battery feed-through socket had developed leakage paths between lugs and between lugs and chassis. With batteries installed, there was 200 microamps of leakage with the radio off, which woulda drained the pack in a few weeks. Another 3000-1 owner also mentioned having a leakage problem in the feed-through socket that drained the batteries.
On mine, i replaced the plug and socket with model airplane style connectors since original parts aren't available. No more leakage. |
