Old 11-22-2013, 04:42 PM
TVTim's Avatar
TVTim TVTim is offline
Sencore
Is a CR161 good for use with televisions of the 80s and 90s?
Old 11-22-2013, 04:47 PM
TVTim's Avatar
Better question is what would be a good, not too expensive, tester/pattern generator for a novice to use?
Old 11-22-2013, 07:17 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
I use a test pattern DVD. Works perfect and I didn't have to rebuild it
If you want a copy of it, PM me your address.
Old 11-22-2013, 07:31 PM
TVTim's Avatar
PM sent. THANK YOU for the offer.
Old 11-22-2013, 07:35 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
If you do decide to use the DVD, be forewarned, the patterns run in an endless loop, only a few seconds for each loop and could cause premature wear on the player.
Pattern generators vary widely in price, what would you consider too expensive? I recently discovered the BK Precision model 1257, which is a very simple portable unit that's available new. The MSRP is $212. More info here:
http://www.bkprecision.com/products/...generator.html
Old 11-22-2013, 07:55 PM
TVTim's Avatar
I'm trying to keep it in the $40ish range. Used in good shape is okay with me.
Old 11-22-2013, 08:09 PM
lnx64's Avatar
lnx64 lnx64 is offline
I thought they just paused the frames and just kept up what was in the RAM.
Old 11-22-2013, 08:25 PM
Jon A.'s Avatar
Not sure if this is important or not, but there would be no sound to accompany the color bars in that case, and the sound with the full-field color bars isn't a steady tone. Then there's the DVD status indicator that would be permanently on, at least on my player.
Old 11-22-2013, 08:31 PM
TVTim's Avatar
That 1257 is a sweet looking machine, but is way out of the price range for the little use I would give it. Nice thought though.
Old 11-22-2013, 08:36 PM
lnx64's Avatar
That's true.. I didn't think about the sound.
Then again I usually am on the white balance gray tones more that have no sound.
Old 11-23-2013, 08:00 AM
The CR161 comes back as a CRT tester not a pattern generator.
As a rule Sencore has the most innovative equiptment BUT
the reliability isnt as high IMHO. B&K is also good, we used both.
If you need a pattern generator almost anything will do fine.
If you need a CRT checker be sure its a modern one maybe
1980 + for several reasons. Also most the time a bad CRT
can be proved with just a good meter.....
Old 11-27-2013, 02:56 AM
ChrisW6ATV ChrisW6ATV is online now
I use one of these devices as a test generator:
http://www.diamondmm.com/mp700-diamo...ia-player.html
It cost $30 at a Fry's Electronics store. You need to be a bit computer-savvy to set it up, but I did it without too much trouble. It has a "combo" button on its remote control that will play sound along with pictures. The only "music" I have on mine is a ten-minute-long 400 Hz tone, and the pictures are Indian-head test patterns and other items all found online, or you can create your own if you want to. Its advantage is that it is very small and has no moving parts at all. It only puts out video, though, no RF, so you would also need an RF modulator for older TV sets.
