Old 11-26-2013, 02:16 PM
What exactly do you mean.... Line Pairing ? What is that....?
Old 11-26-2013, 02:22 PM
That's when the interlacing doesn't happen correctly. Ideally the deflection circuits should get the raster lines of one field fall between the other field's. But sometimes the sync separate circuit doesn't do a good enough job of getting the horizontal out of the vertical, or some other circuit (maybe B+ bypassing) lets some horizontal get into the vertical.
Old 11-26-2013, 04:23 PM
lnx64's Avatar
lnx64 lnx64 is offline
This. These are two fields that are bundled closely together, causing no uniformity.
