Old 11-29-2013, 11:09 AM
radio nut's Avatar
radio nut radio nut is offline
Born in the wrong decade
Well the sound IF coil was junk......tested dead on the primary. The sound still has a slight buzz but even a recalibration does not get it all out. BUT what buzz is present is tolerable and comes on as soon as the cheap dvd player is turned on. one of these days maybe I will get cable and see if its cleaner.
Old 11-29-2013, 11:48 AM
earlyfilm's Avatar
Eternal Member
Originally Posted by radio nut View Post
. . . . what buzz is present is tolerable and comes on as soon as the cheap dvd player is turned on. one of these days maybe I will get cable and see if its cleaner.
Since your Muntz obviously is too old to have a video input, I assume that you are using some sort of a modulator.
Instead of feeding the TV directly, connect a rabbit ears to the TV and just let a 3 foot wire hang from one terminal of your modulator, with no direct connection of the set. This should lower the signal level enough to eliminate buzz from IF overload. It also will isolate the TV from your modulator in case the grounds are different.
And about cable, my newer box has no RF output !!!
James
