Old 12-03-2013, 02:35 AM
StellarTV's Avatar
StellarTV StellarTV is offline
You're getting a few white lines on the screen intermittently? If they're in random spots and pretty bright, you probably have a failing damper tube. Try tapping it with a pencil or screwdriver handle or similar while the sets running. If the tube is bad you'll get lines shooting across the screen and probably sparks inside of the tube.
Also seen this problem with a bad rectifier tube / tube socket.
