Old 12-06-2013, 09:51 PM
Sonora 664 50s metal portable
I recently rescued this little set from a basement along with the Scott 6T11. I searched all over but just couldn't find the back for it. Even so, I saw a lot of potential and brought it home.
The replacement "ECHO Tube Co." 10ABP4 CRT tests like new I think it's a rebuild.
Sure enough, it cleaned up nicely. I think Sandy might say it's "cute as a bug's ear"
For sure it's my new favorite portable.
I'd love to bring it back to life but can't a model # anywhere on it. I looked through all the Riders index but nothing matches. They were out of the TV business by 1960 so I figure it's gotta be around '57-'59.
Any ideas on the model ?
Also any thoughts about replacing that back ?
Maybe fabricate one from scratch or is there a similar model under another brand that might fit
Old 12-07-2013, 07:00 AM
baursam's Avatar
baursam baursam is offline
Bob, this is a guess, no pics but its the only metal case shown. Not much info
http://www.radiomuseum.org/r/sonora_rad_p_1759p175.html
Old 12-07-2013, 07:28 AM
baursam's Avatar
Prob not as it states its a 17 inch portable. That's a big a#& portable.
Old 12-07-2013, 09:21 AM
David Roper's Avatar
console lover
Looking at that big honking sweep tube in there I wonder if this is another true AC/DC set?
tvontheporch.com
Old 12-07-2013, 10:23 AM
egrand
Guest
Posts: n/a
I did some research and here's what I found out so far: Sonora declared bankruptcy in early 1957 and stopped production by a least then, if not earlier. In 1959 Trav'ler bought the name and announced they were going to begin selling products with the Sonora brand again. In other words, Sonoras were just re-branded Trav'lers after that point. I looked at some of the Trav'ler portables from 1959-60 and they sure are the same style as Bob's set.
I have a Sams index from 1962 and I cross refrenced the Trav'lers and Sonoras together. I was able to eliminate some of them, but this is a list of the Sams folders that I can't find any info on to know which models they cover and/or a picture to know if it's Bob's set: 413-2, 472-15, 497-2, 502-2, 541-2
Maybe somebody has these folders and can look to see if they match Bob's set.
Old 12-07-2013, 11:45 AM
Hmm. The only one that looks close is 413-2(models 1730-1731). But it's a 17 inch set. Any models listed that start with a 10?
Old 12-07-2013, 12:21 PM
That is a cute tv.... Boy they crammed a lota stuff into that little cabinet.....
You didn't find a turntable in there did you....?
Old 12-07-2013, 12:56 PM
Think I found it. I can scan or copy as needed.
Old 12-07-2013, 01:16 PM
egrand
Guest
Posts: n/a
Good job finding it! It must have been one of Sonora's last sets and Trav'ler used the design when they bought them out. Some of the Trav'ler sets used the same handle/antenna.
Old 12-07-2013, 01:23 PM
I had a 10" Truetone that used the same handle and antenna, i thought it was a Wells Gardner built set but perhaps not.
Old 12-07-2013, 01:41 PM
DavGoodlin's Avatar
Motorola Minion
I like that set with everything so accessible!
It would be nice to work on compared to all the RCA's I have where you have to remove huge PCB shields and engage in other gymnastics to replace caps.
-Dave G
Old 12-07-2013, 04:22 PM
Awesome! I'd love to have a scan and I'll PM you my email address.
Old 12-07-2013, 06:25 PM
Can't WAIT to see the l'il feller up 'n' runnin'..
Old 12-07-2013, 06:32 PM
Now that I have the Sams, I see this set uses a 0.45 amp filament string. It should have a 8.4 VAC @ 0.45A 10ADP4 CRT , but instead I have a 6.3VAC @ 0.6A 10ABP4
I ran into a similar issue with a Zenith bugeye set. The CRT worked OK, but certainly wasn't as bright as it could be.
Old 12-07-2013, 06:56 PM
Here it is next to an Admiral TS105 so you can really see how bulbous the front is.
