Old 12-24-2013, 12:50 AM
i will recheck the schematic but don't recall seeing any adjustables
Old 12-24-2013, 06:49 AM
Got centering rings ??
Old 12-24-2013, 11:21 AM
yes I tried the centering rings , they pull too , if adjusted so the right side is pulled the left is still pulling , perhaps changing the value of a replaced cap might alter this but I think I might have it to the point now where its not annoying and may just leave it , there is a possibility I didn't think of , there are a couple mica caps in that area I forgot to check , if one is leaky then it could be the fault , perhaps one day I will open it up again and look this over
Old 12-26-2013, 02:12 AM
Tubejunke's Avatar
If he is not interested in converting his set to space command then I might be depending on what it would cost to get the parts from you.
OK, I must not be reading these post closely enough. I just PMd Kramden66 about some other chassis parts and asked him about this. We have seen his answer already, so if you want the Space Command stuff get with me (PM) and we will work something out. The only thing I don't have is the remote its self.
