Since the 99K is the plate load resistor, shunt the 32K that's in series with it. Try maybe a 22K, a 10K, then a full shunt. That'll raise the voltage without losing signal-voltage swing across the 99K. See if this improves volume any. Quote:
http://www.nostalgiaair.org/PagesByM...2/M0013822.pdf Last edited by old_coot88; 12-29-2013 at 05:54 PM. |
Thank you, Mr. Coot
The full voltage did show up with the 85 removed. I tried the series of shunts, but there was no discernible change in volume. I have pretty good volume already.
The alignment was to two caps each on 1st & 2nd IF transformers, then two caps each on the three RF transformers, then the single "oscillator series." I checked the link to the schematic, and it seems OK. I'll put it here, anyway for easier reference even though the readability is marginal. ![]() I'm puzzled with the grid voltages--more often than not I get appropriate values, but negative instead of positive or vice versa, and it seems to work fine. On the 42s here, however, the value seems to be way off. But it still works.
Winky Dink Damn the patina, Full speed ahead! |
