I noticed with the admiral ctc-12 clone that if you tune the picture out to where you almost loose it completely it gets darker and the color level increases , if you yune back to normal its bright and if you turn back too far to where it just shows black and white it still is bright , so I go with the align the ifs then it might be ok , it might even be good to the point where you could use the rejuved crt if you care to.
mike |
