Old 03-08-2014, 07:58 PM
Robb's Avatar
Robb Robb is offline
If you look at your radio, you'll find, an interlocked back panel, set screw knobs and the metal strip holding the chassis and the back panel, isolated from the hot chassis. It wasn't any more dangerous than any other radio made at the time.
So if I touch these back metal parts of the radio, while it is on, I will die ?
flickr
Old 03-08-2014, 08:42 PM
Those are the items I mentioned, as isolated from the line.
IIRC, the rivets near the top, are for a metal shield, to keep the cabinet from being damaged from the heat of the output and rectifier tubes.
