Old 03-20-2014, 06:21 PM
Originally Posted by Kamakiri View Post
If whatever you have gives ohm out specs for the vertical output transformer, that'll get me started.....
It's an unusual design for a B/W vertical output transformer.
The resistance values, per Sams are as follows:
Between the blue and red: 250 ohms.
between the red and the green: 1.8 ohms.
between the green and the black: 17.8 ohms.
Disconnect the green lead from the yoke, to get the truest readings.
The transformer is an autotransformer design and has only one winding with taps.
Sams doesn't show any replacements for it, so hopefully it'll be OK.
