What Olorin said. The mechanism that delays the shutoff works just like the VM changers and is located in the stacked mess underneath the turntable near the bottom of the tone arm. Follow the rods from the record balance arm to where it enters the mechanism and there will likely be a part near that area that's sticky. You'll see how when the balance arm drops completely it pulls on some metal spring wires to trigger this part of the mech. Common problem, had good luck completely soaking that area in penetrating oil and working it around with a long probe.
grundig TW501G
having a problem .the changer will drop the record then lift the tone arm,then just shut off. it does this even if records are stacked.if someone can send a pic and description of when its jamming would help. on an old post , a memeber said he soaked underneath the tone arm with oil and a long rod to get under the slide mech. if someone has figured what the problem is please help me. thank you.send pics please
