Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > The Amateur Radio Spot
Old 07-25-2014, 10:28 AM
init4fun's Avatar
init4fun init4fun is offline
Well , with all this talk of CB radios , I guess we oughta have at least one pictured . Here , in all it's 23 channel glory , is my "Citi-Fone SS" and a good ol D104 . It's got 10 tubes crammed into that little box and a vibrator power supply for 12 Volt as well as a "normal" supply for 115 . It's been recapped and works as well as any old tube CB could , meaning it sits on a shelf with some other bygone relics and collects dust
Old 07-25-2014, 11:31 AM
CB is the only radio system I actively use and experiment on. Screw the regulations. It's so dead out here now that you can do whatever you want on a channel other than 19 and 9 (every once and a while you get chatter from trucks going down the highway so it's best to keep those channels clear) and nobody will ever notice or care. I run a Realistic base station here in the house but as of yet I have been unable to find a way to build the 20' supporting column for the 3/4 wave antenna so my range is limited to two or three kilometers from the house with a craptacular car antenna fitted. I'm sure when the 3/4 wave is up I can get coverage over the entire valley.
On the car there's another Realistic built into the center console and a 12' whip on the back.
I've tried a number of things that technically you shouldn't be doing like RTTY, SSTV and low baud packet. It's all basically useless out here unless your base station has a proper antenna.
Just don't tell anyone I'm doing this, 'kay?
Back when I lived in Vancouver when the weather was just right you could park at the top of the hill in Queen Elizabeth Park and you could got skip from as far away as Alabama. Never understood their love for using channels 6 and 11. It was always a mess of overlapping conversations.
Old 07-25-2014, 07:55 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Think we have one of those lying around here along with an old johnson with no meter just 2 lights and a couple knobs...
SR
