Mitsubishi WD-52725 DLP set curb find
Found this one at the end of the street. Owners were nice enough to leave the original remote with it, heh. It's very clean; looks like it saw infrequent use. It has the common 'rapidly flashing timer LED' issue. I replaced the four 16v 1,000 uF capacitors on the power supply board as instructed, but the problem persists. I do not see any other visibly bad caps on the power supply. On a side note-this TV is definitely put together differently. It's hard to get it apart!
Sony Trinitron Fan Last edited by YamahaFreak; 08-17-2014 at 08:13 PM. |
You must be a masochist...cause IF this is the set I think it is...you have a LOT of work left to do !!
If this set has most of the boards in a bunch of shields", then there are a number of capacitors that need replaced on THREE boards. The power supply...the "formatter" board and the "DM" board. The other two boards are sandwiched together, on the right side of the shield box. There is a big connector that goes from the DMD board to the formatter board. you need to remove the shields around this and then seperate those two boards. There will be a number of 1000/16 or so capacitors on this board, near the top of it, IIRC. ALL of these need to be replaced. The same goes for the DM board behind it. These sets are a BITCH to repair. we ALL hated to work on them in the mid-2000's , when they were still under warranty. A BIG reason was that..about 50% of the time... even when you replaced all of those caps--the set STILL did not work--or work for long. If you have the time and patience--go for it. I no longer DO. I cut myself a lot of times on those damn shields !! I do not wish to do it any more. |
![]() Sourcing and replacing the caps is a cakewalk--the bitch of it is actually getting those damn boards apart and out of the set! I can't figure out how to separate and remove the boards from that metal 'mass' in the lower left of the rear of the set.
Sony Trinitron Fan |
your asking for trouble i am afraid.
Hey, if it's just a bunch of caps, I've got more than enough time and resources :P
Are you sure its worth it for a 720P DLP? I hated to even look at those. Most got thrown away because for the fact their a pain in the ass. That should be the model with the removable front speaker grille. silverish gray color(some are black)
"It's a mad mad mad mad world" !! http://www.youtube.com/user/mwstaton64?feature=mhee |
For me personally, I think so. I'm currently using an intermittently functioning Samsung DLP that needs a DMD board, but this Mits has a better sound system, and, quite frankly, I think it looks better than the Samsung from a design standpoint. This set is black, but yes, it does have the nice removable speaker grille panel on the bottom. Says 'Medallion' on the bottom left corner. I figure all those caps will cost me less cash than the new DMD board. As for 720p, the only source I have that goes to 1080p is a Wii U, and I only have a couple games for that. I'm very happy with the 720p/1080i DLP screen quality, even 480p looks better than the LCDs I have used. I suppose I have a soft spot for DLP TVs too, I like the tech. Would love to own one of the utterly massive 92-inch Mits DLPs, one day...
Sony Trinitron Fan Last edited by YamahaFreak; 08-18-2014 at 03:21 AM. Reason: Punctuation fix |
Those sets aren't bad to watch when they work. It's just one of those sets that bring the curses and bad memories out of any repair person that has ever worked on one.
Back when I was repairing sets for a living, my boss wouldn't let me spend very much time on any DLP. That era of Mitsubishi was very time consuming. We eventually would just turn them away. |
It belongs on the curb.
For sure needs the 4 1000uf caps on the Formatter and DM boards. Then plan on somewhere between a few and about a hundred surface mount caps on those same boards. If you can do that without damaging some traces on the boards, you move on to taking the screen off, and cleaning a ton of dust off of the lens and mirrors.......you get to do that every 6 months or so. Oh yeah. They have a noisy color wheel too. Metallic whirring noise. You get used to it after a while. If you get this far without plunging an axe through it, you might find it is a pretty decent TV. I used one for about 3 years. Even with all of the work I did on it, it would occasionally go quirky on me. I finally got fed up. |
Ironically a friend sent me a text about that same model of mitsu. I had fixed his about 2 years back, the lamp had exploded and I cleaned it all out and replaced the lamp. He said "It has all kinds of white spots on the screen" can it be fixed. I told him to go buy a new TV.
If you want a good set go find a KD-34XBR960
I'm set with my KV-40XBR800 as far as CRTs go.
