Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > Introductions
Old 09-05-2014, 02:03 PM
mpatoray's Avatar
mpatoray mpatoray is offline
The RF input on the XK series of Profeel monitors is a IDC-34 connector, like on a floppy drive. The KV-1311CR had the same connector.
The RGB signal can be either digital or analog, the digital is TTL digital and conforms with the CGA standard.
Analog RGB must have a standard NTSC scan rate, there where adapters for the Atari ST and Apple IIgs to allow the RGB input to be used with those computers.
Old 09-06-2014, 02:13 AM
loui loui is offline
Does this mean the monitor is usable with other 15khz inputs? Or can it only accept rgb from microcomputers
Edit: Apologies, I'm assuming by standard you mean 15khz because correct me if I'm wrong the atarti and apple are both 31khz?.... if so that means I would essentially need to build a cable, but at least I know it is do-able
Thank you mpatoray
