Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > International Vintage Televisions
Old 09-08-2014, 02:36 AM
ppppenguin's Avatar
Originally Posted by NewVista View Post
Actually NTSC wider - 1.3m vs 1 m
With regards to monitoring in PAL-S...
Come to think of it, some monitors had PAL-S & PAL-D switch for convenient signal evaluation (clever).
I think you are sadly misinformed. The IBA Technical Review Volume 2 (a reliable reference) specifies 1.3MHz (-3dB) point for PAL chroma. In System I countries the upper sideband is fully present on transmissions too. In System B/G countries it's a bit marginal.
SMPTE 170M(1993) gives more or less the same figures as for PAL but the USB isn't transmittable in a standard M channel. 170M notes the earlier NTSC standard where Q is 2dB down at 0.4MHz. A lot of NTSC coding has been done with narrowband 600kHz U/V axes rather than the complication of I/Q. This is discussed in SMPTE EG27. I would attach a copy but it's SMPTE copyright. Here's a quote from EG27:
The NTSC encoder described in ANSI/SMPTE
170M uses equal-bandwidth color-difference signals
(either B--Y and R--Y or I and Q). This removes the
need for a delay line in the color-difference signal. A
shorter delay line than required for NTSC 1953 is used
in the luminance (Y) signal (see figure 4).
When this signal is transmitted, a low-pass filter in the
transmitter bandwidth limits the luminance (Y) signal
and the upper sidebands of the color-difference sig-
nals (either B--Y and R--Y or I and Q) to 4.2 MHz.
Transmission of equal-bandwidth color-difference sig-
nals to the receiver has the effect of limiting the
recoverable chroma bandwidth to 0.6 MHz as a result
of the truncation of the upper sidebands of the chroma
modulation in the transmitter’s 4.2 MHz filter. This is
considered acceptable since there are no modern
receivers that utilize the theoretically possible wide-
band I demodulation made possible by maintaining
Old 09-08-2014, 07:04 AM
NewVista's Avatar
NewVista NewVista is offline
Originally Posted by ppppenguin View Post
. The IBA Technical Review Volume 2 (a reliable reference) specifies 1.3MHz (-3dB) point for PAL :
Snell & Wilcox paper contradicts this, claiming NTSC is wider - even saying many encoders maintain 1.3 for I & Q
http://www.snellgroup.com/documents/...des/edecod.pdf
__________________________________________________ ____________
"...there are no modern [NTSC]
band I demodulation.."
What about premium TVs like RCA 'Dimensia' (touted full chroma bandwidth in Ads), Pro-Scan, Sony 'Wega' and the incredible progressive scan Panasonic Xr-series?
Old 09-08-2014, 12:27 PM
ppppenguin's Avatar
Strictly that's John Watkinson's paper, published by S&W. JW is a very well respected engineer here in the UK. His books include "The art of digital audio" and "The art of digital video". Both of these books are always to hand by my desk.
He covers historic practice as stated in the SMPTE docs and then correctly states that modern NTSC coders often use 1.3MHz chroma. This too is correct, my own designs do, as do many others. I don't bother to switch filters when changing between PAL and NTSC. This is fine in the studio. However the upper sideband of a 1.3MHz chroma signal will be heavily mauled by a system M transmitter. Strictly the coders maintain 1.3MHz for U and V, not I and Q. Though if U and V are both 1.3MHz, I and Q will be too.
Poynton, in "A Technical introduction to Digital Video" pp187-190, takes a similar view to Watkinson. He notes that SMPTE170M encourages the use of wideband (1.3MHz) chroma in the studio but also says that the practical broadcast chroma BW is only about 600kHz.
The subtleties of I/Q coding have been largely ignored in practice. Most broadcast coders simply encode on the U/V axes and bandwidth limit before the TX. Hence even a receiver with full chroma BW and I/Q demod will not find any benefit on virtually all material. Any claims like this are markting puff.
Old 09-09-2014, 12:12 AM
NewVista's Avatar
Poynton,..says that the practical [NTSC] broadcast chroma BW is only about 600kHz.
Probably not surprising, but what is wrong with SSB for HF chroma components? as HF Luminance is SSB.
What would be ATSC chroma res (6mhz chnl) vs COFDM chroma res (in 8mhz chnl)?
Old 09-09-2014, 01:11 AM
ppppenguin's Avatar
What would be ASTC chroma res (6mhz chnl) vs COFDM chroma res (in 8mhz chnl)?
All receivers have DSB demodulators for chroma. I haven't done the sums nor have a reference to hand to say what happens when you feed them with a SSB or VSB signal.
ASTC chroma vs COFDM chroma is almost an irrelevant question. Assuming we're talking about standard definition the input to the coder is in each case a standard "601" 4:2:2 signal as defined in SMPTE125M or its Eurpopean eqivalent. The output of the decoder is in the same format. The maximum possible chroma BW is 3.75MHz with a brick wall filter. This is followed by data compession using MPEG. This usually involves subsampling the signal to 4:2:0.
Finally we get to the significant difference between ASTC and DVB, the channel coding. 8VSB for ATSC and COFDM for DVB. Without going into the differences between them or the arguments this has caused it's just a method of carrying a certain bit rate reliably from TX to RX. It has no influence whatsoever on Y or C BW.
Apart from the likely decimation of chroma on the vertical axxis to make 4:2:0, on still pictures what comes out will be very close to what goes in. Any artefacts will depend on how heavily you compress the data. Such artefacts will not normally include any loss of BW. For moving pictures there are additional artefacts which may become visible if too much comrpession is used. Again loss of BW just doesn't happen.
Failure of the channel coding produces different effects. In COFDM this is typically the picture freezing and/or breaking up into blocks. I don't know what happens when 8VSB runs out of eror correction.
Channel width of 6MHz vs 8MHz is simply a consequence of band planning in the repsective countries. It just sets a limit to the bit rate that can be carried using a given channell coding system. I'm not familiar with ATSC but in DVB several programmes will be carreid in each 8MHz channel. These sets of programmes are called multiplexes. The total number depends on how heavily each is compressed and exactly which COFDM modulation schene is chosen. In COFDM parameters such as guard band can be chosen to give higher bit rate or better ruggedness.
Proponents of 8VSB and COFDM modulation have argued the respective merits of their systems but provided you can send the bits from TX to RX without pushing the error correcton over the edge they will have no effect on the pictures. I don't know all the arguments but COFDM is inherently rugged in the presence of multipath while 8VSB needs sophisticated equalisers at the RX which weren't available when it was launched. I think COFDM makes greater demands on TX linearity. The COFDM decoder is more complex as it involves large FFTs. Moore's Law soon dealt with that problem. When you factor in the equalisers needed by 8VSB that probably evens up the complexity. 8VSB is more resistant to doppler effcts if the TX or RX is moving. Not usually a problem for domestic TVs
What is almost certain, but possibly not too important for terrestrial TV, is that COFDM is the most efficient modulation scheme for getting the highest bit rate over a given imperfect channel. It's also very flexible since parameters such as guard band, amount of error correction, bits per symbol and number of carriers can be easily varied without changing the TX or RX. This makes it ideal for ADSL.
Old 09-09-2014, 03:28 PM
I agree with all of this except the efficiency comparison. DVB-T and ATSC are essentially equal in efficiency for the same robustness level of channel coding (but DVB-T has multiple trade-offs of efficiency vs. robustness available). DVB-T2 uses more efficient error protection coding, which will very likely be adopted for ATSC 3.0 as well.
Old 09-09-2014, 04:18 PM
ppppenguin's Avatar
Thanks for the info on relative efficiency of the systems. COFDM makes it inherently easy to trade robustness for bit rate. Even to the point where single frequency networks can be used, because co-channel interference can be rejected in the same way as multipath. It's just a matter of choosing a guardband that adequate and accepting the resultant loss of bit rate. SFNs have not been used in the UK. I don't know about elsewhere.
It's worth noting that COFDM isn't needed on satellite broadcasting systems. The channel is inherently not subject to multipath or selective fading. These are the things that are dealt with by COFDM's multiple carriers, each with low bit rate, plus guard bands. A satellite channel has very high losses due to distance, plus rain fade. These cannot be helped by COFDM. There are also rare occasions when the sun aligns with the satellite. Reception is then impossible for a short period.
Old 09-09-2014, 04:02 PM
Tall towers, that the UHF DTV transmitting antennas are mounted at the top of, tend to sway in the wind. This sway can be as much as a good fraction of a wavelength of the carrier frequency up on UHF. That, combined with some significant ghosts, can make the conditions at a receiver be constantly changing. Which adds extra fun in receiver decoder design...
Old 09-09-2014, 04:09 PM
ppppenguin's Avatar
I think that's only a problem for 8VSB where the equaliser has a lot of work to do. The speed at which the top of the tower moves isn't high enough to give doppler shift that would trouble any plausible COFDM signal.
Old 09-09-2014, 04:20 PM
Doppler performance in COFDM (DVB) is limited by inter-carrier interference between the many closely-spaced carriers. Single carrier (ATSC) Doppler performance is limited by the tracking ability of the receiver equalizer, which is greatly affected by the frequency of transmission of a reference signal. In ATSC for fixed terrestrial reception, the reference sync segment is transmitted approximately 40 times per second, too slow for mobile reception. The mobile adaptation of ATSC transmits a reference approximately 800 times per second during the mobile portion of the data. COFDM achieves mobile performance by using modes with fewer, more widely spaced carriers, and through the use of reference "pilot" carriers that are inserted with the necessary density in time and frequency.
Old 09-09-2014, 03:44 PM
...what is wrong with SSB for HF chroma components? as HF Luminance is SSB.
Basic color analog signal theory:
A single sideband part of the signal produces a quadrature signal component (all frequency components shifted by 90 degrees). A synchronous demodulator will ignore this component if a single SSB signal is transmitted.
However, the chroma signal has two signals transmitted at 90 degree phase difference. Each synchronous chroma demodulator then ignores any quadrature component of its desired chroma component (e.g., R-Y), but sees the quadrature component of the other chroma component (e.g., B-Y).
This is why the original NTSC specs extended only one component (I) into a vestigial sideband region. The I demodulator sees the lower I sideband, and no Q quadrature high frequencies are present because they aren't transmitted; the Q demodulator is narrowband and therefore does not see the quadrature components due to the wideband I signal.
Transmitting wideband on both chroma axes [edit: and then cutting off part of the upper sideband] introduces quadrature distortion of higher frequency chroma, but since receivers are commonly narrowband, they do not see this distorted color detail (or any color detail!). In PAL, some quadrature distortion is tolerable because of the cancellation of phase errors, so more detail can hypothetically be squeezed out of the lower sideband of non-symmetrical chroma sidebands.
