Old 09-09-2014, 07:12 PM
Jon F's Avatar
Jon F Jon F is offline
When you replaced the mica capacitors, does that include the two 900pF ones (c137 and C138 on that schematic, I think) that connect between the horizontal sweep signal outputs and ground? I think they are rated at 1000 or 2000 volts, large "domino"-type capacitors in my chassis. That is on my list of suggested possible fixes, but if you already tried them without success, they would likely not fix my set either.
I did replace both of these. However I did not have the mica's on hand, I used 1000pf instead of 900pf, I don't know if this would have an affect.
Thanks
