Great info! thanks guys. I will be reading the manual.. and try out my existing remote. I will probably get a Roku 2 to pair with it, and keep my eye out for a Blu Ray with analog outputs. It was a beast to move...I will probably have to find a sturdier piece of furniture to put it on. Currently use a 1929 Atwater Kent model 55c in a Keil radio table as a TV stand, but this set will be too large for that.
That is a great find for $10! I still have a 32-inch HS-series Trinitron I also found at GW years ago; it ultimately ended up with the seven blinks standby LED issue, which is supposedly corrected by replacing the MCZ3001D chip(s) in the power supply. One day!
Sony Trinitron Fan |
The big problem with the set is the 2 chips in the
power supply. They will go every few years on average. Be sure if you change them to use sockets, they are a pain & the board is printed on both sides. Besides that I saw 1 or 2 flybacks short, nothing else. I used to have one of these & IMHO it has the BEST pix of any CRT set & any other type display. IIRC the buttons on the set would run everything, & as said will run off almost any Sony remote. 73 Zeno
