Old 10-19-2014, 12:26 AM
Whats the best way to run a set and remove the high voltage ?
Have to touch up the sound and can't get to the adjustments without risking contact with the metal cone of the crt , so what is the best way to run the set and remove the voltage ?
do i just remove the 1B3 and it is safe to run the tv that way or do i remove other tubes ?
mike
Old 10-19-2014, 09:13 AM
N2IXK's Avatar
N2IXK N2IXK is online now
Technohippie
Pulling the 1B3 is probably best, as it will disable ONLY the HV, not the horizontal sweep. Make sure the 1B3 plate lead is well clear of anything (including the tube socket), so it doesn't arc over. You don't actually need to remove the tube, just disconnecting the plate cap is sufficient, as it will keep the 1B3 filament load on the flyback.
Pulling the horizontal output tube as many recommend removes a substantial load from the B+, and will also kill the boost voltage. This may cause a problem for other circuits in the set.
Old 10-19-2014, 10:26 AM
thanks
Old 10-19-2014, 12:15 PM
NoPegs's Avatar
NoPegs NoPegs is offline
The glass is -3dB.
Originally Posted by kramden66 View Post
thanks
You could also just pull the anode lead and put a bottle over it...
Old 10-20-2014, 08:20 PM
Tubejunke's Avatar
Now there's a workable idea that I bet few people would have come up with. Ultimately I would feel better removing the plate cap of the h.v. rectifier(s) as God forbid that bottle move and snap crackle pop with your head in the cabinet! The only DuMont I ever had bore 2 l.v and h.v. rectifiers which is why I referenced 2 of them.
Old 10-21-2014, 05:01 AM
cwmoser's Avatar
cwmoser cwmoser is offline
I've always pondered on this question too thinking it would be nice to
not have that HV when working on other circuits. I have a Philco 48-2500
that appears to have an RF issue that I'm stumped on. I might try removing
the 1B3's to avoid potential radiation and HV issues. BTW, no chance of shock
touching that glass jar when power is removed?
Carl
CW
Old 10-21-2014, 06:18 AM
Remove plate cap, or be very careful and wear good insulating gloves.
If you absolutely have to run it with no picture tube attached, and I can't think of
any reason where that is the only option, I would attache the HV wire to a hv probe
like a voltage probe, and tape it off and put it inside a bicycle tube or similar rubber
protection boot. That way you have a load of some kind, you don't want that voltage spike
reflecting back onto the primary of the HVT.
Old 10-21-2014, 07:15 AM
miniman82's Avatar
First Light: 1952-2011
Why leave the horizontal section running at all? Pull the horizontal output tube and damper, 100% safety.
Evolution...
Old 10-21-2014, 08:30 AM
cwmoser's Avatar
So, just pull the Horizontal Output Tube and Damper Tube?
Should the 1B3 be pulled to?
This bearing in mind that the B+ might be somewhat unloaded.
Carl
CW
Old 10-21-2014, 09:05 AM
N2IXK's Avatar
Technohippie
If you pull the HOT and damper, then no need to pull the 1B3, as it won't be seeing any plate or filament voltage.
But as you say, this will take a significant load off of the B+. This will increase voltages throughout the rest of the set, and will kill the boost voltage, which is needed in some sets to run things like vertical sweep.
When doing an alignment or other critical adjustments, you want the set in as close to a normal operating condition as possible. The least "invasive" way to disable HV is just to disconnect the 1B3 plate cap.
Old 10-21-2014, 10:29 AM
Originally Posted by N2IXK View Post
...This will increase voltages throughout the rest of the set,
...and will kill the boost voltage, which is needed in some sets to run things like vertical sweep.
Not to mention AGC keying pulse (though it's doubtful the set under discussion has keyed AGC).
Old 10-21-2014, 10:38 AM
NoPegs's Avatar
The glass is -3dB.
protection boot.
Bicycle tubes are conductive. Well, at 10kV and up they're not good at insulating, under 250v they're fine. Just letting everyone know.
Concrete is conductive too!
Old 10-21-2014, 11:06 AM
Originally Posted by cwmoser View Post
BTW, no chance of shock touching that glass jar when power is removed?
I have taped the 2nd anode lead inside a jar a bunch of times. The jar won't shock you. Glass is a fine insulator.
Phil Nelson
Phil's Old Radios
Old 10-21-2014, 01:41 PM
cwmoser's Avatar
[QUOTE=Phil Nelson;3117637]I have taped the 2nd anode lead inside a jar a bunch of times. The jar won't shock you. Glass is a fine insulator.
Just double checking that we are not making a "glass jar capacitor" :-)
CW
Old 10-21-2014, 02:35 PM
Not unless you line it inside and out with foil.. whut would be a Leyden jar.
